Check netSpeed and Select the fastest Interface on every restart.
Hi guys
i have 2 vpn client service on my router.
need a script to check the lowest ping speed for both vpn services and set the fastest vpn service to nat firewall settings.
for example
if vpn2 is faster than vpn1, then disable the vpn1 nat firewall setting then enable the vpn2 nat firewall settings.
thank you
