Hi
Is there a way to check if a variable is defined or not? In 2.9 it was possible to do:
:if ([:len $MyVar] = 0) do={ some code }
How to do the same in 3.x?
Hi
You don’t need to check if variable is defined, because you have to define each variable at the beginning of a script in v3.x
OK but i have to keep some information in var for my script (value is also written in script). When MT is restarted the variable isn’t defined and script cannot work.
:global aaa;
:if (:typeof[$aaa] = "nil") do={
but i need it for somewhat
in php
<? php
$offer=5000;
if ( ($var1 = $_GET["price"]) ) {;
echo "your offer : $var1";
;} else {;
$var1=$offer;
echo "no price submited, using current offered ($var1)";
if i forgot to write :
/queue type add kind=pcq name="xSpd private DL" pcq-classifier=dst-address pcq-rate=2M
basically i need value of :
[ /queue type get [ find where name="xSpd private DL" ] pcq-rate ]
then assign that value into $var1,
however if i applied into mikrotik :
:local fullspeed "5000";
:if ( (:local var1 [ /queue type get [ find where name="xSpd private DL" ] pcq-rate ]) ) do={
/log info ( "speed = (" . $var1 . ") " );
;} else={;
:local var1 = $fullspeed ;
/log warning ( "speed = use our default value (" . $var1 . ") " ) ;
it doesnt working then i expected, whats wrong ? any ideas ?
You are defining var1 in different scopes multiple times.
Code should be:
:local var1 [ /queue type get [ find where name="xSpd private DL" ] pcq-rate ];
:if ($var1 ....) do={
} else={
:set var1 $fullspeed
sorry for late reply … i never thought it was already replied … thank u …
hmm …
yes its working … it should be …
my script also ( i think ) …
here i types via winbox terminal :
so when i print to console :
:put [ /queue type get [ find where name="xSpd private DL" ] pcq-rate ]
it will return : “2000000”
then i create script via winbox : system → script
:if ( (:len [ /queue type get [ find where name="xSpd private DL" ] pcq-rate ]) > 100 ) do={;
/log warning ("YES" );
;} else={
/log warning ("NO")
in log window : “YES”
its working … YAY!!! ![]()
BUT, when i :
/queue type remove "xSpd private DL"
then i run the script
where is /log warning (“NO”) go ? there is no “YES” or “NO”.
including what youve instructed sir, there is no error sign, there is no success sign
:if ($var1 > 100) do={
/log warning ( "YES" );
} else={
/log warning ( "NO" )
now : is it a variable ?
if yes : how “Checking if a variable is defined?”
if no : how “tocheck rule was created?”
or : how can i check is error?
in php i just write : if ( isset ($whatVariable) ){ … ;}else{…;}; /or just/ if ( ($whatVariable) ){ … ;}else{…;};
or did i missed something important ? since that day, i cant go any further … its because i want to “add” or “set” (if a variable was defined) rules
ive RB450G MikroTik RouterOS 6.33.1 (c) 1999-2015, and there rest of myRB result still same.
