Checking Status If Netflix is Down Or Not?
Found this New tool on the block www.netflixdown.com It allows you to check the status if Netflix service is down or not in your region. If the service is working fine, it even prompts you to check your internet or ISP issues for that matter.
Guys have you checked out the tool yet. And if yes do you have any suggestions for it.
The tool doesn’t work now. It used to work before. What happened? any idea?
What does this have to with MT??
Is there anything to do with Mikrotik?
