This is a code
scheduler-A
#set variables
:local pingcount 3
:local ipA 192.168.0.22
:local ipB 192.168.1.22#ping gateways with src
:local pingresultA [/ping 8.8.8.8 src-address=$ipA count=$pingcount]
:local pingresultB [/ping 8.8.8.8 src-address=$ipB count=$pingcount]#if link_A is UP
:if (($pingresultA=3)) do={
#send email
/tool e-mail send subject=($ipA . " is up ")
body=(“the gateway is up now at: " . [/system clock get date]) \ to=(”> test@gmail.com> ") tls=yes#enable scheduler-Both
/system scheduler set [find name=ping_google_link_Both] disabled=no
#disablescheduler-B
/system scheduler set [find name=ping_google_link_B] disabled=yes
#disable scheduler-A
/system scheduler set [find name=ping_google_link_A] disabled=yes}
scheduler-B
#set variables
:local pingcount 3
:local pingresultB [/ping 8.8.8.8 src-address=$ipB count=$pingcount]#if Link_B is UP
:if (($pingresultB=3)) do={
#send email
/tool e-mail send subject=($ipB . " is up ")
#disable scheduler-B
/system scheduler set [find name=ping_google_link_B] disabled=yes}
scheduler-Both#set variables
:local pingcount 3
:global state no#ping gateways with src
:local pingresultB [/ping 8.8.8.8 src-address=$ipB count=$pingcount]#if link_A is DOWN and link_B is UP then:
:if (($pingresultA=0) && ($pingresultB>0)) do={
#send email
/tool e-mail send subject=($ipA . " is down")
body=(“the gateway is down now at: " . [/system clock get date]) \ to=(”> test@gmail.com> ") tls=yes#disable scheduler-A
/system scheduler set [find name=ping_google_link_A] disabled=no
#disable scheduler-Both
/system scheduler set [find name=ping_google_link_Both] disabled=yes
}#if link_A is UP and link_B is DOWN then:
:if (($pingresultA>0) && ($pingresultB=0)) do={
#send email
/tool e-mail send subject=($ipB . " is down")
body=(“the gateway is down now at: " . [/system clock get date]) \ to=(”> test@gmail.com> ") tls=yes#disable scheduler-B
/system scheduler set [find name=ping_google_link_B] disabled=no
/system scheduler set [find name=ping_google_link_Both] disabled=yes}
and this is schedule
/system scheduler
add disabled=yes interval=5s name=ping_google_link_B on-event=scheduler-B
policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api
start-date=jan/01/1970 start-time=00:00:00
add interval=5s name=ping_google_link_Both on-event=scheduler-Both policy=
add disabled=yes interval=5s name=ping_google_link_A on-event=scheduler-A
policy=
When count is strating in schedule i can see that Both is active, when something went wrong it should inform me and active script must be that which interface is in problem. So when I tried to disable a another wan interface, nothing happend, counting of schedule is still raising, like nothing happend. I tried to use a first usable line of script which tests a ping from a lanIP, and when I disabled interface ping is lost, so that part is working, i cant just figure out why the rest (informing, and changing to script of lost interface) is not working.
BtW i found this script here http://phallaccmt.blogspot.rs/2016/02/mikrotik-schedulscript-check-wans-to.html
