Hello guys,
I am new here and also new to Mikrotik, I have only RB260GS switch
I want to ask for help with choosing Mikrotik products for my home network.
At this moment I have cable modem Ubee EWV3226 which has some routing capabilities and has also wifi. That Ubee is not bad but my ISP flashed it with their firmware which is very very bad. It’s connection to network is stable but routing and wifi is not working as I want. Opening ports in NAT is lottery sometimes. I want to switch it to bridge mode and use Mikrotik router for routing.
I also want WIFI at home, 2,4GHz, no need for 5GHz (only two devices at home can use it and only one (my phone) is using wifi), also I don’t care if the wireless is 100mbit or xxxxmbit. My internet speed is 150/10 at this moment,I do not plan to go on higher speed, more probably I will lower it.
Now I have dilema with which devices to buy. My problem with wireless is that I want stable a good connection in all rooms at my house, speed is not problem. I don’t need coverage outside the house.
Modem is placed under wooden stairs. I should describe the house, it is 13 metres long and 5,5 metres width. It has two floors. If you divide the house to three parts (by long side, 13/3) - the end parts are living parts of house with rooms (living room with kitchen and homeoffice room at 1st floor, bedroom and childern room on 2nd floor). Middle parts are stairs, bathrooms, entrance, corridors. The house is wooden (2by4 system) with walls made of ekopanel - panels 6-12cm made of pressurised straw.
Now, Ubee’s wifi is good only at middle and it’s 1/3 living part of house. On the other side, it has problems with connection.
I borrowed Unifi AP AC Lite, placed it next to modem and it covered house great.
Now, I was thinking at first about RB951G-2HnD as WIFI router but I am afraid that it won’t cover the house properly. Positioning in the middle of house is hard and my wife won’t allow that big thing with 5 ports to be places on wall in corridor (also, it will be hard to place cables there from modem and to other parts of the house). So I cannot move it to best place. Maybe a little but there will still be stairs..
So then I thought about one device for routing and second one as wireless AP (someone on this forum suggested it
. Thinking about hEX, RB750Gr2 or RB750Gr3. Which would be more suitable for home use? I will use VPN to get inside my network probably and for sure vpn to make all freewifi hotspots safe. Maybe a few NAT ports and blocking P2P. r3 has dualcore processor but it is a new device and probably some baby bugs? Atheros seem to be in my eyes more prooved.
Another question is wifi AP. I thought about cAP and place it on the ceiling of corridor downstairs - exact middle of house
. But there is not much information about cAP, if it is good or not. And it’s antennas has lower gain 2dBi then RB951G 2dBi - may this difference be compensated by better placement? There is also cheaper cAP lite with 1,5dBi antennas, wAP which seems to be the same as cAP. And hAP ac lite which is big (will need to cover it like RB951G or place on worse place) but has 5Ghz support - which is good for future?
I can afford now RB750Gr3 with cAPlite, maybe cAP/wAP.
Or RB750Gr2 and RB951G as AP which can be placed somewhere on better place then under the stairs.
edit2: seems that RB750Gr2 is discontinued and I can found it only as used, so probably the first option is more possible
Or would be RB951G enough for both routing and as WIFI AP (with not best placement, but unifi ap worked good with stronger antennas).
Edit2: I found very cheap used RB751U-2HnD, 2,5dBi antenna but only one. Don’t know what is better. 2x2dBi or 1x2,5dBi..
Thank you for any advice ![]()
edit: sorry for long post ![]()
