The problem is on 2.4 GHz, but not on all setups. I have one setup where WiFi links directly into the wired network, where DNS server is Windows Server. There everything works swell.
However, on three other WiFi networks which are isolated (own bridges and ranges), it sometimes work, and sometimes don’t.
I actually think I am screwed by Firewall rule “add action=drop chain=input comment=“Disallow other” log=yes log-prefix=\ “INPUT DROP ALL OTHER”” but I really don’t understand why.
Here is
CAPSMAN router config, and I will post the CAP one below;
add name=INTERNET
add name=PINKY
add name=VIDEONADZOR
add name=WiFi-GOSTI
add name=WiFi-PINKY
add name=WiFi-SKLADISTE
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-SW1
set [ find default-name=ether3 ] name=ether3-SW2
set [ find default-name=ether4 ] name=ether4-SW3
set [ find default-name=ether5 ] name=ether5-PoESW1
set [ find default-name=ether6 ] name=ether6-GRICKO
set [ find default-name=ether7 ] name=ether7-SKVIKI
set [ find default-name=ether8 ] name=ether8-HRCAK
set [ find default-name=ether9 ] name=ether9-LINK-CARINSKO
set [ find default-name=ether10 ] disabled=yes name=ether10-VIDEONADZOR
set [ find default-name=sfp1 ] name=sfp1-LINK-STAKLARSKA1
/caps-man configuration
add channel.band=2ghz-onlyn channel.extension-channel=disabled country=\
no_country_set datapath.bridge=WiFi-PINKY distance=indoors \
installation=indoor mode=ap name=PINKY security.authentication-types=\
wpa2-psk security.encryption=aes-ccm security.passphrase=PASSPHRASE \
ssid=PINKY
add channel.band=2ghz-b/g/n channel.extension-channel=disabled country=\
no_country_set datapath.bridge=WiFi-GOSTI distance=indoors installation=\
indoor mode=ap name=GUESTS security.authentication-types=wpa2-psk \
security.encryption=aes-ccm security.passphrase=PASSPHRASE ssid=\
GUESTS
add country=no_country_set datapath.bridge=PINKY distance=indoors \
installation=indoor mode=ap name=LINK security.authentication-types=\
wpa2-psk security.encryption=aes-ccm security.passphrase=PASSPHRASE ssid=\
LINK
no_country_set datapath.bridge=WiFi-SKLADISTE distance=indoors \
installation=indoor mode=ap name=SKLADISTE security.authentication-types=\
SKLADISTE
add name=PINKY-LAN
add name=lan-PINKY-pool ranges=192.168.10.40-192.168.10.240
add name=wifi-PINKY-pool ranges=192.168.40.2-192.168.40.254
add name=wifi-gosti-pool ranges=192.168.50.2-192.168.50.254
add name=wifi-skladiste-pool ranges=192.168.30.2-192.168.30.254
add address-pool=lan-PINKY-pool disabled=no interface=PINKY name=\
lan-PINKY-dhcp
add address-pool=wifi-PINKY-pool disabled=no interface=WiFi-PINKY \
name=wifi-PINKY-dhcp
add address-pool=wifi-gosti-pool disabled=no interface=WiFi-GOSTI name=\
wifi-gosti-dhcp
add address-pool=wifi-skladiste-pool disabled=no interface=WiFi-SKLADISTE name=\
wifi-skladiste-dhcp
/caps-man access-list
add allow-signal-out-of-range=10s ap-tx-limit=1000000 comment=\
"GUESTS limit, 500k -> 3.5MB/s" disabled=no ssid-regexp=GUESTS
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes upgrade-policy=\
suggest-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=PINKY
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
PINKY name-format=prefix-identity name-prefix=CAP-2.4GHz \
slave-configurations=SKLADISTE,GUESTS,LINK
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
LINK name-format=prefix-identity name-prefix=CAP-5GHz slave-configurations=\
PINKY
/dude
set enabled=yes
add bridge=PINKY interface=ether2-SW1
add bridge=PINKY interface=ether3-SW2
add bridge=PINKY interface=ether4-SW3
add bridge=PINKY interface=ether5-PoESW1
add bridge=PINKY interface=ether6-GRICKO
add bridge=PINKY interface=ether7-SKVIKI
add bridge=PINKY interface=ether8-HRCAK
add bridge=VIDEONADZOR interface=ether10-VIDEONADZOR
add bridge=PINKY interface=sfp1-LINK-STAKLARSKA1
add bridge=PINKY interface=ether9-LINK-CARINSKO
add bridge=INTERNET interface=ether1-WAN
add interface=ether2-SW1 list=PINKY-LAN
add interface=ether3-SW2 list=PINKY-LAN
add interface=ether4-SW3 list=PINKY-LAN
add interface=ether5-PoESW1 list=PINKY-LAN
add interface=ether6-GRICKO list=PINKY-LAN
add interface=ether7-SKVIKI list=PINKY-LAN
add interface=ether8-HRCAK list=PINKY-LAN
add interface=ether9-LINK-CARINSKO list=PINKY-LAN
add interface=sfp1-LINK-STAKLARSKA1 list=PINKY-LAN
add address=192.168.10.1/24 interface=PINKY network=192.168.10.0
add address=192.168.40.1/24 interface=WiFi-PINKY network=192.168.40.0
add address=192.168.50.1/24 interface=WiFi-GOSTI network=192.168.50.0
add address=192.168.30.1/24 interface=WiFi-SKLADISTE network=192.168.30.0
add address=192.168.0.2/24 interface=INTERNET network=192.168.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=INTERNET
add address=192.168.10.0/24 caps-manager=192.168.10.1 dns-server=\
192.168.10.13,192.168.10.10,192.168.10.1 domain=PINKY.local gateway=\
192.168.10.1 ntp-server=192.168.10.1
add address=192.168.30.0/24 dns-server=192.168.30.1 gateway=192.168.30.1
add address=192.168.40.0/24 dns-server=192.168.40.1 gateway=192.168.40.1
add address=192.168.50.0/24 dns-server=192.168.50.1 gateway=192.168.50.1
set allow-remote-requests=yes servers=\
8.8.8.8,8.8.4.4,1.1.1.1,1.0.0.1,216.146.35.35,216.146.36.36
/ip firewall address-list
add address=192.168.10.2-192.168.10.254 list=allowed_to_router
established,related,untracked
invalid log=yes log-prefix="DROP INVALID INPUT "
add action=accept chain=input comment="Allow IP range" src-address-list=\
allowed_to_router
add action=drop chain=input comment="Disallow other" log=yes log-prefix=\
"INPUT DROP ALL OTHER"
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=forward comment="ACCEPT PORT FORWARD" \
connection-nat-state=dstnat
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid log=yes log-prefix="DROP INVALID FORWARD "
connection-state=new in-interface=INTERNET
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=INTERNET
add action=dst-nat chain=dstnat dst-port=3389 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.10 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3948 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.12 to-ports=3389
add action=dst-nat chain=dstnat dst-port=1433 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.12 to-ports=1433
add action=dst-nat chain=dstnat dst-port=2001 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.12 to-ports=2001
add action=dst-nat chain=dstnat dst-port=2002 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.12 to-ports=2002
add action=dst-nat chain=dstnat dst-port=21001 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.12 to-ports=21001
add action=dst-nat chain=dstnat dst-port=22001 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.12 to-ports=22001
add action=dst-nat chain=dstnat dst-port=12301 in-interface=INTERNET protocol=\
tcp to-addresses=192.168.10.12 to-ports=12301
add distance=1 gateway=192.168.0.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set backlight-timeout=never default-screen=stats read-only-mode=yes
/lcd interface
add interface=PINKY
add interface=VIDEONADZOR
add interface=INTERNET
add interface=WiFi-PINKY
add interface=WiFi-GOSTI
/lcd interface pages
set 0 interfaces="ether1-WAN,ether2-SW1,ether3-SW2,ether4-SW3,ether5-PoESW1,ethe\
r6-GRICKO,ether7-SKVIKI,ether8-HRCAK,ether9-LINK-CARINSKO,ether10-VIDEONADZO\
R,sfp1-LINK-STAKLARSKA1"
/system clock
set time-zone-name=Europe/Zagr
/system identity
set name="TRNOSCICA - GLAVNI O
/system ntp client
set enabled=yes primary-ntp=21
/system ntp server
set enabled=yes
/system package update
set channel=long-term
/tool graphing
set store-every=hour
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
set allowed-interface-list=non
/tool mac-server mac-winbox
set allowed-interface-list=MAR
/tool mac-server ping
