Hello, i have installed a chr on cloud vm and i am trying to create some firewall rules in order to secure my router.
my problem is that my rules doesn’t work, it seems like they get bypass!! for example ssh and winbox are allowed while i have an input rule to drop everything from wan. also my bruteforce rules are not “catching” packets, they should count traffic these rules.
bellow is my config:
set [ find default-name=ether1 ] disable-running-check=no
add name=LAN
add name=WAN
/port
set 0 name=serial0
set discover-interface-list=none
/ipv6 settings
set disable-ipv6=yes
add interface=ether1 list=WAN
add address=5.XXXX.XXXX.196/24 interface=ether1 network=5.XXX.XXX.0
/ip dhcp-client
add disabled=yes interface=ether1
set servers=XXXXXXXXX,XXXXXXX
add action=add-src-to-address-list address-list="port scanners" \
address-list-timeout=2w chain=input comment="Port Scanners to list" \
protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input comment="NMAP FIN stealth scan" \
protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" protocol=\
tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=input comment="ALL/ALL scan" protocol=tcp \
tcp-flags=fin,syn,rst,psh,ack,urg
address-list-timeout=2w chain=input comment="NMAP NULL scan" protocol=tcp \
tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment="SYN/FIN scan" protocol=tcp \
tcp-flags=fin,syn
address-list-timeout=2w chain=input comment="SYN/RST scan" protocol=tcp \
tcp-flags=syn,rst
add action=jump chain=input comment="SYN Flood INPUT" connection-state=new \
jump-target=syn-attack protocol=tcp tcp-flags=syn
add action=add-src-to-address-list address-list=bruteforce_blacklist \
address-list-timeout=1d chain=input comment=Blacklist connection-state=\
new dst-port=1026,8292 protocol=tcp src-address-list=connection3
add action=add-src-to-address-list address-list=connection3 \
address-list-timeout=1h chain=input comment="Third attempt" \
connection-state=new dst-port=1026,8292 protocol=tcp src-address-list=\
connection2,!secured
add action=add-src-to-address-list address-list=connection2 \
address-list-timeout=15m chain=input comment="Second attempt" \
connection1
add action=add-src-to-address-list address-list=connection1 \
address-list-timeout=5m chain=input comment="First attempt" \
add action=accept chain=input comment="bruteforce ssh&winbox" disabled=yes \
dst-port=1026,8292 protocol=tcp src-address-list=!bruteforce_blacklist
add action=accept chain=input comment="WG VPN Rule" dst-port=13231 protocol=\
udp
established,related,untracked
invalid
add action=drop chain=input src-address-list="port scanners"
add action=drop chain=input comment="defconf: drop all not coming from LAN"
add action=jump chain=forward comment="SYN Flood FW" connection-state=new \
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=syn-attack connection-state=new limit=400,5:packet \
add action=drop chain=syn-attack connection-state=new log=yes log-prefix=\
SYN-ATK protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
/ip firewall raw
add action=drop chain=prerouting dst-port=53 in-interface-list=WAN log=yes \
log-prefix="WAN DNS" protocol=udp
add dst-address=0.0.0.0/0 gateway=5.XXXX.XXXX.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=1026
set api disabled=yes
set winbox port=8292
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/Amsterdam
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
what i am configuring wrong? why firewall is not working properly? i have only 1 interface ether1 and is in WAN interface list. the accept input rule for winbox and ssh it is disabled but still i can connect. i have tried to clear connection tracker and reboot the chr.
