CHR and max MTU
Hi MT,
I couldn’t find if this had been discussed already, but does the CHR fix the issue with large L2MTU? I know we had issues before CHR when using x86 RouterOS on ESX and MTU’s above 1500. If so, what is the max MTU for CHR?
Rich
BUMP
I would really like to know about this as I am using CHR on Unetlabs and I think I have ran into the MTU greater than 1500 problem
It works. I’m using on VMware and as long as you set the MTU on the VNIC to, say, 9000 then you can use large MTU’s on the CHR guest.
