the CHR download section does not have arm64 extra packages.
Are the standard ROS arm64 extra packages (officially) compatible?
Best regards
Virsacer
Best regards
Virsacer
Yes, you can upgrade and install additional packages using the regular npk files.
VDI and raw images are used to deploy a new installation.
