CHR - Broken upgrade from RouterOS 7.1 b4
I am consistently unable to upgrade any of my systems from RouterOS 7.1 beta 4. I attempt the upgrade by using
/system/package/update/set channel=development
/system/package/update/check-for-updates
/system/package/update/download
/system/reboot
On reboot the VM hangs with 1 core at 100% CPU. So far it does not matter what configuration I use, and I have had this happen on multiple hosts, now. I have reproduced it with a CHR that is only configured with an IP and DNS.
your beta is 2 years old
start from scratch with new beta
last beta is 7.1beta6
Sorry, typed the wrong version number: 7.1 beta 4.
Try setting up a new server with beta 6. There was an issue with beta 4 and earlier, if I recall it was something to do with the partition table format being incorrect. It may be the cause of the issues you are having.
I appreciate the advice! To be clear, I don’t require assistance in resolving the issue (I nuked the instance and restored from backup to the latest beta), I just want to make sure it is known - and it sounds like it is. Sorry to create noise, I just could not find anything on it!
Do not report bugs from the old beta,
if you know any bugs, try it on the current version and report it in the appropriate thread.
Thanks.
