CHR cloud-init
I found a work around using the qemu agent to run scripts not perfect but its usable
I want to auto provision some CHR for our customers
I see that in the docs there is mention of AWS and GCloud there when it comes to auto provsioning
eg I want to be able to at least set and IP address on an interface so I can get access via the API and then I can finish the config off
any ideas how to do that
so that at least at first boot the IP address will be set on the lan interface
thanks
Just add your comments to user data. This is a snippet from cloudformation:
UserData:
Fn::Base64:
!Sub |
/system identity set name=gw1
Thanks for that tip so they are calling cloudformation API
I wonder if that is some custom thing they have in there code anyway its a start thanks
