CHR guest agent
Does anyone know how to enable qm guest agent in CHR so that it can communicate Proxmox with CHR, I am using routeros version 6.48.6 in my lab.
I have enabled in the Proxmox part the Agent check but it does not detect the guest in CHR.
Greetings
…not quite sure what you are saying here, but virtio network (and disk) drivers should work out-of-the-box, hence no need to install them in CHR image separately.
There is no need to enable these things, they are available or they aren’t.
E.g. in VMware ESXi the “vmware tools” is installed in CHR. At least now it is, some time ago that wasn’t the case and it showed the same message.
Maybe it depends on what image file you use for the install, use the one that seems most appropriate for the hypervisor. (I use OVA for ESXi)
https://www.qemu.org/docs/master/interop/qemu-ga-ref.html
I don´t think there is support in CHR for GA, but I don´t think you really need this.
Some features would be useful, anyway:
  • -suspend
    -monitor
    -info
    -file operations related stuff
