CHR Image is not compatible with IPv6? (DigitalOcean)
I've been using MikroTik for a few years now, and I'm wanting to configure a gateway to my network which doesn't expose my personal IP address directly. I've used a DigitalOcean VPS running Mikrotik CHR with a level 1 license in the past, but I was kneecapped because the droplet didn't support IPv6. I attempted to add IPv6 on, several ways, but eventually was told that the only way was to erase the droplet and restart it from scratch.
Well, I'm doing that, now...but still no joy. I get an error message, "Image is not compatible with ipv6" every time I attempt to pull the trigger. I don't want to end up in the same situation as last time, when I couldn't get the setup to work properly at all and had to start over. Any suggestions?
I believe it's a general limitation of custom images in DigitalOcean and the only way to circumvent it I can think of is to use tunnel brokers like Hurricane Electric
