Just spin up chr-6.44.6.vhdx inside Hyper-V VM trying to have playground instead of playing with real 951G-2HnD.
VM have 4 network legacy ports. All of them are attached to Hyper-V “internal” virtual switch. ether1 and ether2 are LAN (no VLAN ID), and ether3 and ether4 have set VLAN ID.
I have added ports ether1 and ether2 into bridge1. Assign IP 10.0.1.3 to bridge1.
I have added ports ether3 and ether4 into bridge2. Assign IP 10.0.2.3 to bridge2.
When IP 10.0.1.3 was on ether1 I can ping and connect to it with WinBOX from other VM (also on internal virtual switch with IP 10.0.1.11). From CHR terminal I can ping both IP’s.
When I move IP 10.0.1.3 from ether1 to bridge1 I cannot ping anymore IP from VM. Stil I can ping both IP’s on bridges from CHR terminal.
I can see in WinBOX while connected to CHR that Switch tab is missing while I have that one on real 951G.
Do you have any advice ? Is it possible to have two bridged ports with IP inside VM and connect to that IP with WinBOX ?
Thank you
Regards
Nenad
