CHR License
I’m new to CHR. What i’m asking is about the license. My license just as below:
sys license print
        system-id: aHBQkZvxR\C
            level: p-unlimited
  next-renewal-at: may/05/2017 20:59:59
      deadline-at: jun/04/2017 20:59:59
Do i have to renew it within next-renewal & deadline time?
If so, can i use another mikrotik account to renew instead of my old account before?
Thanks.
No. You can keep it running even after the deadline but you will not be able to update to newer version.
License is not transferable between the accounts so far but there are such and similar requests already. I have not seen any official statement about such future possibilities from mikrotik yet.
So, if the period’s over… How can I get newer version upgrades? Renew the license or Regenerate ID?
Is the license paid? Then just keep the chr to be able to reach the licensing server with the correct account and everything will be updated automatically.
Looks like this is not valid anymore… check this:
https://mikrotik.com/client/transferprepaid
Deadline just means when the CHR will check if license is not moved somewhere. All you need is internet at this date, then it will auto-extend.
If there is no text “limited upgrades”, it means the license was Paid when last checked.
I have similar problem, i buy a CHR key, and cant upgrade to last ROS, i tried to Renew licence i put user and password and the window tellme “done” but still see the flag red inside my account and the date not renew.
system-id: lX0gJOOn8tH
             level: p1
  limited-upgrades: yes
   next-renewal-at: may/18/2017 04:48:44
       deadline-at: apr/14/2017 20:59:59
Hey guys,
I have some kind of the same issue with CHR license.
It was registered with free license on the an account.
Now I want to renew license under a new account and it gives me “not permitted error”.
Please advise!
Thank you
If your trial period ran out (60 days), you can not acquire new trial for the same CHR instance. You can either upgrade to paid license (available for 60days after the end of the trial period) or install a new CHR.
