chr lost system ID
I have several chr installed with trial key.
A want to upgrade this, but I can’t find some system id on my account.
How can i solve this problem without reinstall these systems?
I can upgrade this chr’s with my account, but the id not shown on the web site.
Another question:
Can I delete the old, unused chr id’s from the wen site?
http://wiki.mikrotik.com/wiki/Manual:CHR#Getting_the_License
Hi jarda,
I’m already read wiki and search similar topic on the web.
Like this: http://forum.mikrotik.com/t/transfer-chr-trial-licence/101872/1
Normis wrote, license transfer is not possible between accounts. (Wiki doesn’t contain information about it!)
It is very bad news, because on a live system not the best thing to make reinstall etc.
Fortunately a lot of chr are part an HA system, so reinstall is solvable. But it is a very uncomfortable thing!
When I build a virtual system for a customer I have’nt access my customer mikrotiks account. So I install it with my account.
After the system is working and the customer is ready to take over, we will change root/Administrator etc passwords.
But the license managment not, because isn’t possible.
Do you understand my problem?
For my another questions can’t find any solution.
I lost some system id from my account. Trial license is workin, but I cannot upgrade it. Transfer “system id” isn’t possible.
Thrid uncomfortable thing is a lot of unnecessary old license on my account.
Solution 1: make temporary accounts, but “system id” transfer isn’t possible to a live account. (and upgrade is to P1 etc)
Solution 2: make a lot of account for all project. Keep in mind a lot of account information… :slight_smile:
(Sorry for my poor english)
You don’t need to transfer between accounts, this would not solve anything.
The issue is purely with how you used trial. If trial goes past 60 days, you can’t purchase a key for it anymore. Reinstall is required.
I know this causes issues for you, but otherwise nobody would purchase keys in time, if you could just Trial for unlimited time. 60 days pass and System ID is gone.
I understand now. It is not technical problem but commercial that mikrotik doesn’t support transfer of licences between the customers. In this case write to support and try to convince them, maybe they can do it individually upon a specially justified request.
Yes, the system is not meant for the workflow you described. The customer must use his own account when testing.
  1. We will think if and how to support situations where somebody needs to configure and test a system and then give it to somebody else
  2. Trial must be paid before 60 days is over
Normis, thank you for your reply!
I think the best solution will be the system id based transfer possibility. With or without purchased license.
System integrators would be very happy :slight_smile:
On MUM hungary I tried to contact you, but it failed for lack of time.
I have several ideas to improve web management for chr licenses. Some other information will be helpful.
Linked below.
