CHR move license?
Hi, I have a CHR on a datacenter with Mikrotik… server has any trouble because if I restart or update server still not accesible and need to restart through kvm…
My question is… I bought license 4… can I “export” this license to another server to change server because this has a trouble?
If yes, how I do it?
Best regards!!
Yes, if you use CHR and not the ISO then the license can be moved to other systems, even while the old one is still running. check your account.
Hi, thx for your prompt reply, in this case, I need to go to System-License and export key?
Then in new server go to System-License and import key?
Thx!!
