CHR on HyperV shows "unknown" and "incomplete" on interfaces status
Hi all
I have installed Mikrotik CHR chdx on a Hyper-V 2012 R2 server. It boots, and i am able to manage it throuwh Winbox, but the firewall nat rules are not being applied. I worries me that when I open interface propierties on any of them, and go to the Status tab, in autonegotiation and Rate, it says incomplete and unknown respectively.
Its a Generation 1 VM, with a normal Network Interface (not legacy), and i am running the latest CHR RC versión 6.42rc6 but i get the same behaviour woth the stable versión, and with legacy network adapters.
Have any of you faces this same problema?
Kind regards!
Autonegotiation incomplete and Rate unknown are normal on a CHR.
Let’s see your config. export then.
