The company I work for uses alot of scripts across both CHRs and routerboards. To validate if the script is currently running on a CHR or a routerboard we have always used the “/system routerboard get routerboard” command.
It seems like that this has been removed in CHRs on ROS7. In ROS6 it would always generate false/true based on if it was a CHR or a routerboard.
Does anyone know if this will be brought back in ROS7 or if there is a better way to accomplish it?
I have not been able to find any information why this was removed from ROS7 CHRs.
If you want to test it on your own device you can run:
:local test [/system routerboard get routerboard]; :put $test
From RouterOS 7.15 system resource get board-name includes also the virtualization platform like “CHR VMware, Inc. VMware Virtual Platform”, so I’ve update the check in this way.
