CHR running Dude and CAPsMAN not working v.6.37
Hi all,
Hopefully someone can provide some assistance with the following issue before i have to rebuild my database device by device.
Had 6.36.3 running no issue and waited a while for 6.37 to be out.
I installed 6.37 earlier and the dude updated and works well but when logging onto the system i see that the CAPsMAN option is not there as the wireless package never installed. I tried to add it but then saw that the device had a kernel panic and crashed leaving the package disabled and CAPsMAN-less.
I have had to revert to 6.36.3 once again but now my database schema is not working and dont know how to restore my database.
My only other option i have come to conclusion with is to spin up another CHR (free license 1Mb) and utilize this on 6.36.3 with CAPsMAN as my CAPsMAN just manages the config of the devices as all my traffic is done at the endpoints
Any ideas how i can omit having to have another VM
same here,
can’t activate wireless package on chr 6.37
just opened a support case with MikroTik … will keep you updated
Just received a mail from MT support:
We have released 6.38rc version with necessary fix. Can you please upgrade your router, make sure that problem is gone and report back to us with results?
Best regards,
Martins S.
I confirm, it works :wink:
