CHR stability
Hello everyone,
I keep experiencing CHR instability as in they keep rebooting once per day. 6 months ago they had uptime of 100+ days, however with recent flood of upgrades we started having issues. Specially after that one release that had issues with HyperV virtualization. The issue was presented to be fixed, and it was definitely better but after upgrading to 6.40.9 and 6.42.9 the issues started repeating again.
Anyone had similar experience?
What the logs say?
I mean the logs from the hypervisor…
I am also having the same issue. I am logging to disk and memory and nothing out of the normal shows. I only see “system,error,critical - router was rebooted without proper shutdown” after it comes back online. This too started happening since the last round of firmware updates that have come out. I am currently running on 6.43.2 and still have the issue.
Is there a better logging rule that might shed some more light on the issue? i currently just have the default logging but have it logging to disk also. Below are you logging settings;
/system logging action
set 0 memory-lines=10000
set 1 disk-file-name=flash/SystemLog disk-lines-per-file=10000
/system logging
add action=disk topics=info
add action=disk topics=error
add action=disk topics=warning
add action=disk topics=critical
Sure you cannot see anything in the ros. You should look into the logs of hypervisor to see why the host was stopped.
