CHR trial license key
Hi, how can I obtain trial (60-days) key for my CHR installation?
I’ve tried to generate it with customer’s portal on mikrotik.com, but it seems to be available just for x86 or hardware installations, since my system-id key didn’t fit the field in a questionary :frowning:
CHR has a special section, don’t go into the old keys section.
I’ve noticed that, but this section doesn’t work for me either https://cloud.mail.ru/public/MQ9L/S75QRyJ4A
Did you log into your account from your CHR router? You must do that first. Then the router will appear in your account.
Oh, this make sense :slight_smile: Thanks!
