hi every body
i have i problem in my chr
when i run bandwidth test tx still on 1119 or less but rx work normally and the traffic up to 10G
i test that on sfp 10G
i test that on bonding
and i open ticket with mikrotik support before 4 days without any response
Btest is single threaded so it can not describe the routing performance of the device. If you would like to test the performance, use two devices on sides as traffic generators and put tested equipment in the middle of them.
btest on a chr with a 10-gig network card will do 9.999 Gig through the network to another physical box
btest on a chr to another chr hosted on the same hypervisor (with mnxnet3 ) will hit 17 to 19+ gig or more depending on the physical hardware
my CHR license P10 and only limit on TX or RX on both i install CHR on
esxi un limited core
my vm
64 core
128 Ram
i have 3 network card i try E1000-E100e-vmnex3
2 SFP+ HP card
4 Ethernet 1G each interface
builtin card hp 4 Ethernet two interface 1G and two interface 10G
I have a problem with each traffic more than 1G
p10
p10 (perpetual-10) license level allows CHR to run indefinitely. It is limited to 10Gbps upload per interface. All the rest of the features provided by CHR are available without restrictions. It is possible to upgrade p10 to p-unlimited After the upgrade is purchased the former license will become available for later use on your account.
What is on the way between those two devices? How their processors look like during that load? How this device look like when the traffic generators are neighbouring pushing the traffic through? And don’t use btest if you would like to get serious results.
