Hello
At some site we are currently running virtualized RouterOS instances on ESX since 2-3 years, ie. before CHR was released.
Overall this works fine but i was wondering if there was a case in migrating towards CHR ?
Any insight / advice you might have would be most welcome.
CHR and the regular x86 version of RouterOS should be mostly identical. I can think of only the following differences:
- They are licensed differently
- CHR is 64-bit whereas RouterOS x86 is (officially) 32-bit only
- CHR contains various VirtIO drivers. I’m not sure if regular RouterOS x86 contains them as well.
Cha0s
3
I believe this is the major advantage over x86 installations.
It allows for 10g networking in a virtualized environment.
https://wiki.mikrotik.com/wiki/Manual:CHR
Usable Network and Disk interfaces on various hypervisors:
ESX:
Network: vmxnet3, E1000
Disk: IDE, VMware paravirtual SCSI, LSI Logic SAS, LSI Logic Parallel
Hyper-V:
Network: Network adapter, Legacy Network adapter
Disk: IDE, SCSI
Qemu/KVM:
Network: Virtio, E1000, vmxnet3 (optional)
Disk: IDE, Sata, Virtio
Xen Project:
Network: E1000, rtl8193, netfront
Disk: IDE, Sata
VirtualBox
Disk: IDE, Sata, SCSI, SAS
We unfortunately don’t run 10Gb yet so, as long as it works (which is the case so far), there would not be any significant advantage to move to CHR ?
Cha0s
5
If you don’t need more than 2GB of ram (x86 limitation) or more than 1gbit interfaces then I don’t see any good reason to migrate to CHR just yet.
