CHR - WiFi card not detected
I installed RouterOS CHR 7.15.3 on a virtual machine (VirtualBox on Ubuntu), but WiFi card is not detected: when I run “ip address print”, nothing is printed (while it is printed one Ethernet interface when I start the virtual machine with an Ethernet cabled on host PC).
Does anyone get the same problem? Is it a known issue?
Thank you so much
ROS can’t handle any network cards when running as CHR in a virtual machine. You’ll need to configure the WiFi card in Ubuntu first, then add it to VirtualBox as a regular network interface.
Thank you for the reply.
I already done it, but only with WiFi it does not work… I tried again today and now it works (maybe there was a problem with my WiFi…). So no problem!
