CHR x86 ethernet interfaces random names
Hi!
Once and once again im facing problem with CHR x86 interface names on EVE virtual enviroment.
Interface names are named in some random fashion after reboot and i can not find the root of such behavior.
Example:
[admin@R-02] /routing bgp peer> /interface ethernet export
# jan/07/2018 18:11:02 by RouterOS 6.41
set [ find default-name=ether2 ] name=ether1
set [ find default-name=ether3 ] name=ether2
set [ find default-name=ether4 ] name=ether3
set [ find default-name=ether1 ] name=ether4
Wiki says “for any other reason interfaces on the router are renamed”:
https://wiki.mikrotik.com/wiki/Tips_and_Tricks_for_Beginners_and_Experienced_Users_of_RouterOS#Make_sure_that_interface_names_are_correct
Any fix on that?
Hi
Did you siolve this issue?
I’m running through the same problems.
@Vooray did you ever find a solution to this? I’m seeing the same thing in my environment
set [ find default-name=ether3 ] name=ether1 speed=1Gbps
set [ find default-name=ether4 ] name=ether2 speed=1Gbps
set [ find default-name=ether1 ] name=ether3 speed=1Gbps
set [ find default-name=ether2 ] name=ether4 speed=1Gbps
Cisco CDP Neighbors show as below even though in my test environment they’re connected on ether1
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
MikroTik         Gig 0/2              111               R            MikroTik  ether3
Does this affect you being able ping to and from the WAN interface of the Mikrotik instance?
I’m having this issue, very strange
Hello, I have this issue too.
I’ve tested it on 6.39.3 (bugfix), 6.40.8(bugfix), 6.42.6 on Vmware and KVM/QENU.
Is it any solution?
Regards,
MMS101
I am facing the same problem. I created a CHR and added 8 ethernet interfaces, one by one as I already know about this issue,
hoping that they will keep the same name. After every interface I added I renamed it from ether1 to ether1-purpose1 etc until ether8-purpose8
and after having done all that only 2 of them have kept the name in /interface print while it still is set in /export.
After reboot the mapping between default-name and given name is a complete jumble.
And the interfaces do not connect to the correct networks either!
HELP!
Running which version?
There’s something about this in 6.44beta.
I am running 6.43.1 (stable)
I found that after a reset-to-defaults the name mapping appears consistent.
Maybe I should have added all interfaces at once before first boot instead of one-by-one while the router was running…
(I hoped that the software would build a mapping from PCI-ID or MAC-Address to interface number)
However, now that I have done that it has become very unstable. It crashes with “Irq without vector” messages.
Should I try with the RC?
