chromecast does not work on HAPac2 5ghz network
Hi all, I am new to the Mikrotik world.
I have a HEX with two internet connections in load balancing mode as my main router and 02 HAPac2 access points managed by capsman on HEX
everything is working correctly and I can access everything on my network except that chromecast doesnt work when connecting to the 5Ghz network (AC)
I have 2 chromecast devices: androidTV connected to the HAP via wifi (2.4ghz) and a Nest audio which
both chromecasts are visible and working if I connect anywhere on the network on the 2.4GHZ or if I connect my laptop with LAN cable
however when I am on the 5ghz network it doesnt work
below is the HAP exported file and after is the HEX
HAP>>>>>
add admin-mac=DC:2C:6E:F5:66:43 auto-mac=no name=bridgeLocal
/interface wireless
# managed by CAPsMAN
# channel: 2447/20-Ce/gn(17dBm), SSID: Am, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
# channel: 5180/20-Ceee/ac/P(20dBm), SSID: Am, CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik
add name=WAN
add name=LAN
add bridge=*B disabled=yes interface=*C
add bridge=bridgeLocal interface=all
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal enabled=yes interfaces=wlan1,wlan2
add address=192.168.1.100/24 interface=ether2 network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=yes interface=bridgeLocal
set servers=192.168.1.1,8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat src-address=172.17.0.0/16
/system clock
set time-zone-name=Africa/Cairo
/system identity
set name=HAPac2-A
/system package update
set channel=testing
/system routerboard reset-button
set enabled=yes
HEX>>>>
/caps-man channel
add name=2.4
add name=5.0
add name=LAN
set [ find default-name=ether1 ] name="ether1-WAN1 TE"
set [ find default-name=ether2 ] name="ether2-WAN2 VF"
set [ find default-name=ether3 ] name=ether3-free
set [ find default-name=ether4 ] name=ether4-Y
set [ find default-name=ether5 ] name=ether5-A
/caps-man datapath
add bridge=LAN name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=A
add authentication-types=wpa2-psk encryption=aes-ccm name=Y
/caps-man configuration
add country=egypt datapath=datapath1 distance=indoors mode=ap name=A \
    security=Amir ssid=Am
add country=egypt datapath=datapath1 distance=indoors mode=ap name=Y \
    security=Yousef ssid=MA
/caps-man interface
add configuration=A disabled=no l2mtu=1600 mac-address=DC:2C:6E:F5:66:48 \
    master-interface=none name=HAPac2-A-1 radio-mac=DC:2C:6E:F5:66:48 \
    radio-name=DC2C6EF56648
add configuration=Y disabled=no l2mtu=1600 mac-address=DE:2C:6E:F5:66:48 \
    master-interface=HAPac2-A-1 name=HAPac2-A-1-1 radio-mac=00:00:00:00:00:00 \
    radio-name=DE2C6EF56648
add configuration=Amir disabled=no l2mtu=1600 mac-address=DC:2C:6E:F5:66:49 \
    master-interface=none name=HAPac2-A-2 radio-mac=DC:2C:6E:F5:66:49 \
    radio-name=DC2C6EF56649
add configuration=Y disabled=no l2mtu=1600 mac-address=DE:2C:6E:F5:66:49 \
    master-interface=HAPac2-A-2 name=HAPac2-A-2-1 radio-mac=00:00:00:00:00:00 \
    radio-name=DE2C6EF56649
add configuration=A disabled=no l2mtu=1600 mac-address=DC:2C:6E:F5:66:33 \
    master-interface=none name=HAPac2-Y-1 radio-mac=DC:2C:6E:F5:66:33 \
    radio-name=DC2C6EF56633
add configuration=Y disabled=no l2mtu=1600 mac-address=DE:2C:6E:F5:66:33 \
    master-interface=HAPac2-Y-1 name=HAPac2-Y-1-1 radio-mac=00:00:00:00:00:00 \
    radio-name=DE2C6EF56633
add configuration=A disabled=no l2mtu=1600 mac-address=DC:2C:6E:F5:66:34 \
    master-interface=none name=HAPac2-Y-2 radio-mac=DC:2C:6E:F5:66:34 \
    radio-name=DC2C6EF56634
add configuration=Y disabled=no l2mtu=1600 mac-address=DE:2C:6E:F5:66:34 \
    master-interface=HAPac2-Y-2 name=HAPac2-Y-2-1 radio-mac=00:00:00:00:00:00 \
    radio-name=DE2C6EF56634
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool0 interface=LAN name=LAN-DHCP
/port
set 0 name=serial0
/routing table
add disabled=no fib name=to-WAN1
add disabled=no fib name=to-WAN2
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-enabled master-configuration=Amir name-format=prefix-identity \
    slave-configurations=Yousef
add bridge=LAN interface=ether5-A
add bridge=LAN interface=ether4-Y
add bridge=LAN interface=ether3-free
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
    all wan-interface-list=all
add address=192.168.2.10/24 interface="ether1-WAN1 TE" network=192.168.2.0
add address=192.168.3.10/24 interface="ether2-WAN2 VF" network=192.168.3.0
add address=192.168.1.1/24 interface=LAN network=192.168.1.0
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1
set servers=8.8.8.8,8.8.4.4
/ip firewall mangle
add action=accept chain=prerouting comment=accept dst-address=192.168.2.0/24
add action=accept chain=prerouting dst-address=192.168.3.0/24
add action=accept chain=prerouting dst-address=192.168.1.0/24
add action=mark-connection chain=input comment=input in-interface=\
    "ether1-WAN1 TE" new-connection-mark=WAN1
add action=mark-connection chain=input in-interface="ether2-WAN2 VF" \
    new-connection-mark=WAN2
add action=mark-connection chain=prerouting comment=mark-conn in-interface=\
add action=mark-connection chain=prerouting in-interface="ether2-WAN2 VF" \
add action=mark-connection chain=prerouting comment=PCC dst-address-type=local \
    in-interface=LAN new-connection-mark=WAN1 per-connection-classifier=\
    both-addresses:2/0
add action=mark-connection chain=prerouting dst-address-type=local \
    in-interface=LAN new-connection-mark=WAN2 per-connection-classifier=\
    both-addresses:2/1
add action=mark-routing chain=output comment=Output connection-mark=WAN1 \
    new-routing-mark=to-WAN1
add action=mark-routing chain=output connection-mark=WAN2 new-routing-mark=\
    to-WAN2
add action=mark-routing chain=prerouting comment=Mark-route connection-mark=\
    WAN1 in-interface=LAN new-routing-mark=to-WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2 in-interface=LAN \
    new-routing-mark=to-WAN2
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-table=main \
    suppress-hw-offload=no
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-table=main \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-table=to-WAN1 \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-table=to-WAN2 \
May I ask why you use CAPsMAN in this use case?
Can you reset the cAP ac’s to CAP mode? I can see you have configured two bridges (though one is disabled). And a lot more router configuration still present.
https://help.mikrotik.com/docs/display/ROS/Reset+Button
I have the same expirience, when Im on the 5GHZ and the chromecast on 2,4Hgz I can not stream from My mobile. I use mikrotik only as router AP are diffrent brand…
