Chromecast From Wifi to LAN?
I currently have a hAP ac2 with two wireless networks (2.4 and 5ghz), and a LAN. No VLANs are configured, and all wireless and internal LAN interfaces are considered equally trustworthy (I don’t have a guest network or similar). I’m attempting to use from various Android wireless devices (smartphones/tablets/etc) to a wired smart tv. The wireless devices can see the smart tv and everything is on the same subnet, but casting consistently fails. AP Isolation is turned off.
I was able to get this working with an old SOHO Netgear router just by turning off isolation on the wireless AP, so I’m reasonably confident the issue is how I have the Mikrotik router configured.
Is there a guide on how to do this? Are there additional settings I need to cast from apps on Android devices (e.g. Hulu, Youtube, etc)?
[admin@MikroTik] > export hide-sensitive verbose
# jan/15/2020 20:17:12 by RouterOS 6.44.1
# software id = 5HS3-1Y19
# model = RBD52G-5HacD2HnD
# serial number = [Redacted]
add admin-mac=74:4D:28:8B:A7:D9 ageing-time=5m arp=enabled arp-timeout=auto auto-mac=no comment=defconf dhcp-snooping=no disabled=no fast-forward=yes forward-delay=15s igmp-snooping=no max-message-age=20s mtu=auto name=bridge priority=0x8000 protocol-mode=rstp transmit-hold-count=6 vlan-filtering=no
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s \
    mac-address=74:4D:28:8B:A7:D8 mtu=1500 name=ether1 orig-mac-address=74:4D:28:8B:A7:D8 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s \
    mac-address=74:4D:28:8B:A7:D9 mtu=1500 name=ether2 orig-mac-address=74:4D:28:8B:A7:D9 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s \
    mac-address=74:4D:28:8B:A7:DA mtu=1500 name=ether3 orig-mac-address=74:4D:28:8B:A7:DA rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s \
    mac-address=74:4D:28:8B:A7:DB mtu=1500 name=ether4 orig-mac-address=74:4D:28:8B:A7:DB rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s \
    mac-address=74:4D:28:8B:A7:DC mtu=1500 name=ether5 orig-mac-address=74:4D:28:8B:A7:DC rx-flow-control=off speed=1Gbps tx-flow-control=off
/queue interface
set bridge queue=no-queue
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 2 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 3 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 4 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 5 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set [ find name=all ] comment="contains all interfaces" exclude="" include="" name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" include="" name=dynamic
add comment=defconf exclude="" include="" name=WAN
add comment=defconf exclude="" include="" name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types="" disable-pmkid=no eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m interim-update=0s management-protection=disabled mode=none mschapv2-username="" name=default radius-called-format=mac:ssid radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-sta-private-algo=none static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none \
    tls-mode=no-certificates unicast-ciphers=aes-ccm
add authentication-types=wpa-psk,wpa2-psk disable-pmkid=no eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m interim-update=0s management-protection=allowed mode=dynamic-keys mschapv2-username="" name=JoshWifi radius-called-format=mac:ssid radius-eap-accounting=no radius-mac-accounting=no \
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=2 area="" arp=enabled arp-timeout=auto band=2ghz-b/g/n basic-rates-a/g=6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-XX compression=no \
    country="united states3" default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes disable-running-check=no disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0 frequency=auto frequency-mode=regulatory-domain frequency-offset=0 guard-interval=any \
    hide-ssid=no ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 hw-fragmentation-threshold=disabled hw-protection-mode=\
    none hw-protection-threshold=0 hw-retries=7 installation=indoor interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 mac-address=74:4D:28:8B:A7:DD max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=enabled multicast-helper=default name=wlan1 nv2-cell-radius=30 \
    nv2-downlink-ratio=50 nv2-mode=dynamic-downlink nv2-qos=default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both radio-name=744D288BA7DD rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default secondary-channel="" security-profile=\
    JoshWifi ssid=PrettyFlyForAWifi-2G station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled \
    vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 wmm-support=disabled wps-mode=push-button
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=2 area="" arp=enabled arp-timeout=auto band=5ghz-a/n/ac basic-rates-a/g=6Mbps bridge-mode=enabled channel-width=20/40/80mhz-XXXX compression=no country=\
    "united states3" default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes disable-running-check=no disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0 frequency=auto frequency-mode=regulatory-domain frequency-offset=0 guard-interval=any hide-ssid=no \
    ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 installation=indoor interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 mac-address=74:4D:28:8B:A7:DE max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=enabled multicast-helper=default name=wlan2 nv2-cell-radius=30 nv2-downlink-ratio=50 \
    nv2-mode=dynamic-downlink nv2-qos=default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both radio-name=744D288BA7DE rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default secondary-channel="" security-profile=JoshWifi ssid=\
    PrettyFlyForAWifi-5G station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2 tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled vht-basic-mcs=mcs0-7 vht-supported-mcs=\
    mcs0-9,mcs0-9,mcs0-9 vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 wmm-support=disabled wps-mode=push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17
set wlan2 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=flash/hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=default !parent-queue !queue-type shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1 lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=modp1024
add address-pool=default-dhcp authoritative=yes bootp-support=static disabled=no interface=bridge lease-script="" lease-time=23h name=defconf use-radius=no
/ppp profile
set *0 address-list="" !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list !local-address name=default on-down="" on-up="" only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit \
    !remote-address !session-timeout use-compression=default use-encryption=default use-mpls=default use-upnp=default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list !local-address name=default-encryption on-down="" on-up="" only-one=default !outgoing-filter !parent-queue \
    !queue-type !rate-limit !remote-address !session-timeout use-compression=default use-encryption=yes use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set wlan1 queue=wireless-default
set wlan2 queue=wireless-default
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id !confederation disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 !mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out redistribute-bgp=no \
    redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 !routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5 encryption-protocol=DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=flash/log disk-lines-per-file=1000 disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=bsd-syslog target=remote
/user group
set read name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude skin=default
set write name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude skin=default
set full name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path="" require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=yes crl-store=system crl-use=yes
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=ether2 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=\
    0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=ether3 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=\
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=ether4 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=\
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=ether5 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=\
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=no interface=wlan1 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=\
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=no interface=wlan2 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=\
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s \
    tcp-unacked-timeout=5m udp-stream-timeout=3m udp-timeout=10s
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=yes send-redirects=yes tcp-syncookies=no
/interface detect-internet
set detect-interface-list=none internet-interface-list=none lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 caller-id-type=ip-address default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=no
add comment=defconf disabled=no interface=bridge list=LAN
add comment=defconf disabled=no interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:EF:AA:E0:1C:61 max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any verify-client-certificate=no
/interface wireless access-list
add allow-signal-out-of-range=10s ap-tx-limit=0 authentication=yes client-tx-limit=0 comment="Josh Pixel Smartphone" disabled=no forwarding=yes interface=wlan2 mac-address=3C:28:6D:DB:6F:9B private-algo=none signal-range=-120..120 !time vlan-id=1 vlan-mode=no-tag
add allow-signal-out-of-range=10s ap-tx-limit=0 authentication=yes client-tx-limit=0 comment="Josh Windows Laptop" disabled=no forwarding=yes interface=wlan2 mac-address=14:AB:C5:7C:B5:7D private-algo=none signal-range=-120..120 !time vlan-id=1 vlan-mode=no-tag
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" caps-man-names="" certificate=none discovery-interfaces="" enabled=no interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.88.1/24 comment=defconf disabled=no interface=bridge network=192.168.88.0
/ip cloud
set ddns-enabled=no ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-client
add add-default-route=yes comment=defconf default-route-distance=1 dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
/ip dhcp-server lease
add address=192.168.88.254 address-lists="" client-id=1:2c:56:dc:3c:e:8d dhcp-option="" disabled=no !insert-queue-before mac-address=2C:56:DC:3C:0E:8D server=defconf
add address=192.168.88.0/24 caps-manager="" comment=defconf dhcp-option="" dns-server="" gateway=192.168.88.1 ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-concurrent-queries=100 max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s servers=""
/ip dns static
add address=192.168.88.1 disabled=no name=router.lan regexp="" ttl=1d
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=no
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=no in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=no
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN !to-addresses !to-ports
add action=dst-nat chain=dstnat comment="RDP to Desktop" !connection-bytes !connection-limit !connection-mark !connection-rate !connection-type !content disabled=no !dscp !dst-address !dst-address-list !dst-address-type !dst-limit dst-port=999 !fragment !hotspot !icmp-options !in-bridge-port \
    !in-bridge-port-list in-interface=all-ethernet !in-interface-list !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list !packet-mark !packet-size !per-connection-classifier !port !priority \
    protocol=tcp !psd !random !routing-mark !routing-table !src-address !src-address-list !src-address-type !src-mac-address !src-port !tcp-mss !time !tls-host to-addresses=192.168.88.254 to-ports=3389 !ttl
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=all src-address=::/0 template=yes
/ip ipsec settings
set xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no max-cache-object-size=2048KiB max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=:: parent-proxy-port=0 port=8080 \
    serialize-connections=no src-address=::
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/flash/pub disabled=no max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no host-key-size=2048 strong-crypto=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=32k enabled=no inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=yes nat-dst-port=yes \
    nat-src-address=yes nat-src-port=yes out-interface=yes packets=yes protocol=yes src-address=yes src-address-mask=yes src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=no routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public trap-generators=temp-exception trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=America/Chicago
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
add action=memory disabled=no prefix="" topics=firewall
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
/system resource irq rps
set ether1 disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
/system routerboard settings
set auto-upgrade=no boot-device=nand-if-fail-then-ethernet boot-protocol=bootp protected-routerboot=disabled reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard mode-button
set enabled=no on-event=""
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any filter-interface="" filter-ip-address="" filter-ip-protocol="" filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" filter-operator-between-entries=or filter-port="" filter-stream=no memory-limit=100KiB memory-scroll=yes \
    only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=no stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s use-radius=no
Your config shows CAPSMAN etc. MPLS etc. ? You are using that, you don;t mention it…?
I have various Chromecast working well in same subnet (means all i/f are in the same bridge and all clients on that bridge can use Chromecast).
Issues I have seen in the past (all related to firewall):
  • BOGON, some BOGON address are indeed used by Chromecast. But seems you do not filter them
add action=accept chain=input comment=“ICMP from Chromecast into Router” in-interface=Bridge_Chromecast_on log-prefix=
Accept_Chromecast_ICMP_ protocol=icmp
You need to allow PING on INPUT chain from Chromecast (don;t ask me why it needs it)
<br>
* You aslo need to let Chromecast PING 8.8.8.8 (Google DNS server)
```text
add action=accept chain=icmp_chain comment="ICMP on Chromecast" dst-address=8.8.8.8 in-interface=Bridge_Chromecast_on log-prefix=\
    Accept_ICMP_Chromecast protocol=icmp
And please , don’t use “verbose” when doing export :slight_smile: (shows also all default settings… confusing…)
Thanks for the feedback. I configured the firewall rules you suggested, and still no luck. However some further testing did reveal that if I move the smart tv to the wireless interface (rather than having it on an ethernet interface) casting works fine. This is leading me to wonder if it's some type of issue with multicast traffic not being passed between the WLAN and LAN interfaces despite them being on the same bridge, or if the WLAN and LAN interfaces don't share the same broadcast domain.
Updated copy of the config below:
jan/16/2020 06:15:08 by RouterOS 6.44.1
add admin-mac=74:4D:28:8B:A7:D9 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=dynamic-keys name=JoshWifi supplicant-identity=MikroTik wpa-pre-shared-key=callofduty wpa2-pre-shared-key=callofduty
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge security-profile=JoshWifi ssid=PrettyFlyForAWifi-2G wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge security-profile=JoshWifi ssid=PrettyFlyForAWifi-5G wireless-protocol=802.11
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge lease-time=23h name=defconf
add bridge=bridge comment=defconf interface=wlan2
add comment="Josh Pixel Smartphone" interface=wlan2 mac-address=3C:28:6D:DB:6F:9B vlan-mode=no-tag
add comment="Josh Windows Laptop" interface=wlan2 mac-address=14:AB:C5:7C:B5:7D vlan-mode=no-tag
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.88.254 client-id=1:2c:56:dc:3c:e:8d mac-address=2C:56:DC:3C:0E:8D server=defconf
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="ICMP from Chromecast into Router" in-interface=bridge log=yes log-prefix="\Accept_Chromecast_ICMP_" protocol=icmp
add action=accept chain=icmp_chain comment="ICMP on Chromecast" dst-address=8.8.8.8 in-interface=bridge log=yes log-prefix="\Accept_ICMP_Chromecast" protocol=icmp
add action=dst-nat chain=dstnat comment="RDP to Desktop" dst-port=999 in-interface=all-ethernet protocol=tcp to-addresses=192.168.88.254 to-ports=3389
/system clock
set time-zone-name=America/Chicago
/system logging
add topics=firewall
/tool mac-server
Can you confirm:
  • Your Chromecast gets internet? (You see the nice Google Photos on TV screen if that works).
  • All clients do have internet and can also see each other already (when you do LAN scan with your phone)
    If above it is all ok, then what I would do :
    Enable Logging of the “DROP” rules (under ACTION in the firewall rule tab).
    Then you try to connect on Phone to Chromecast you will see it logging (if its an Firewall issue).
PS: I have seen on my ROS 6.46.1 some strange behaviour recently on Wifi.
Despite that I enabled “Authentication” in the Wifi i/f settings it did not accept new clients.
I had to created an Access List entry for that Wifi interface. Leave the MAC address empty (means all devices) and
select “FORWARD”, and “AUTHENTICATE”.
After that all clients could connect and forward data…
Not sure if its related but worth a trial:
/interface wireless access-list add comment="Allow connections from anyone" forwarding=yes interface=YOUR_Wifi vlan-mode=no-tag
