Chromecast sleepmode issue
Ive faced with non typical problem: chrome cast devices dont work in native sleep mode with mikrotik. Ive changed my TVs for newer (Samsung 7 series, LG) wich have chromecast functin and i can send video content from phone to TV and this works perfect. BUT... in sleep mode TV must me accessible too and when user sends chromecast content to TV then TV must power on and start youtube ar scrinmorroring or basicaly power on remotely and this option works from any other router by default (ive this on tested tp-link, zyxel, asus, edimax). As i found, after i turn off TV ping to it available 5-20 seconds than TV become unavailable. I`ve spent two week for searching the solution bu i failed. I have two devices for test: hap lite and hAP AC Lite RB952Ui in default mode. One TV connected via ethernet dirrectly to Mikrotik and other connected via cable to switch then to mikrotik. Can you help me with this?
So your TV is connected using wired ethernet, not wireless, right?
Do you see the state of the ethernet port change when the TV enters sleep mode?
(go down, or go back to 10 Mbit/s for example)
Yes, wired connection. After tv power off port stay online and even has some tx packets but has no RX. Different link modes didn`t help. Same issue was with wireless connection. Thats why connected cable, wanted to exclude wireless configuration.
Yes I would think wireless has more chance of failing due to some special mode not implemented or so.
With wired ethernet you should always set it to AUTO negotiate and allow all speed/duplex values (= the default setting).
Setting hardcoded speed/duplex at one side of an ethernet link is a bad idea.
Some devices will re-negotiate when they go to sleep mode e.g. from 1 Gbps to 100 or 10 Mbps.
Link has manual configuration 100 full duplex, before this was 10… same result
That is likely the problem. Change it to AUTO.
:slight_smile:
Problem isnt so simple. All "simple" things were tested. Different link speed, auto link, dhcp reservation time, static ip, upnp, add mutlicast, loop protect disable, disable all firewall deny rules, changed arp lifetime, different vlan for TV and chromecast laptop that has wired connection. Thats why the last chance is registration here and ask for help, i have no ideas what it can be.
Try increasing DHCP lease-timeout=1d . I know Apple things have issues with the short default lease time.
Edit: just re-read your last post where you changed it, but it might not have been long enough.
In any case, manual config of ethernet settings is almost always a bad thing to do, and it CERTAINLY is a bad thing when it cannot be done on both sides. Presuming you cannot set it on the TV side, you also should not set it on the router side! (i.e. leave it at auto negotiate)
To solve this problem you will need to have detailed looks at the link state (as I already mentioned) and make packet traces to see what exactly ceases to work. Does it fail at the IP level or even at the ARP level. Is there any indication that the device loses its IP address. Could it be an IPv6-related problem (e.g. IPv6 fails but IPv4 keeps working, is however not used because IPv6 worked before).
TVs use only ipv4, no option for ipv6. As i wrote before, port indication stay active for mikrotik ethernet2 with direct tv connection and for swith where connected second tv. In TV standby mode it deletes from active hosts on mikrotik so i think problem is on arp level. I think its some specific standby mode that doesnt support by default and need to be activated but i have no idea what it can be. Its really frustrating because i was able to solve any problem with mikrotik before but not this time and i cant replace mikrotik with other device because im using l2tp tunnels, over 50 firewall rules and rras server (for test im using router with default setting). I gave only one idea… add one more router after mikrotik but it`s very stupid for one function add router after router.
“connected via cable to switch then to mikrotik”
Maybe the problem is not layer 1 or not even layer 2. But a higher layer (such as IP routes) or layer 2 helper service (multicast snooping, broadcast flood, STP protocol, loop detect …).
What else is in the path from content transmitter to TV? Does your transmitter initialy find the chromecast device?
Some hints here: https://developers.google.com/cast/docs/discovery
And here ? http://forum.mikrotik.com/t/google-chromecast/104986/1
Probably time to share your config… :slight_smile:
Could it be firewall?
My Chromecast HDMI stick does PING 8.8.8.8, and needs to succeed…
I don’t know such a mode on wired ethernet that requires more than the default auto-negotiate being enabled.
(some devices reduce the ethernet speed when in sleepmode, what you should see in the log is a loss of ethernet link, re-negotiate, and come back at a lower speed)
Thank you for the answer. I`ve specially connected two devices on different ways:
  1. All devices had wireless connection that can make many problems. Then ive changed connection to wired for All devices (2 TVs and one laptop). Third thought was that mikrotik can disable port in tv standby mode so ive connected one TV to twitch so in mikrotik port will be power on all time.
  2. All works perfect when TVs powered on. Can send chromecast, do screenmirroring and control remotely with Google Home from any device (laptop, pc, phone) but when i send TV to standby mode then all devices can`t see it after 10-20 seconds. First 10 seconds i can wake it when send chromecast content.
  3. Different parameters for flood, loop, stp, upnp and ports snooping didnt help. Tried configure multicast package and this didnt help too.
  4. Took new router with DEFAULT settings, disabled all deny firewall rules.
Sad thing that 10$ simplest routers can do this from the box and even have no settings for this
Cane somebody test chromecast on tv with mikrotik router?
https://www.google.com/search?q=chromecast+Mikrotik&oq=chromecast+Mikrotik
i`ve stopped at 14th page. All articles are around “Make chromecast work” and dated 2014-2017 years. In samsung tvs it starts from 7th series and, as i think, after 2018 year
I have tested it with my Philips TV with Android and built-in Chromecast.
It works fine. TV is in standby (connected wired ethernet), I turn on my HP Chromebook (which is on WiFi) and select casting, it already sees the TV and I can connect it, TV powers on.
Heck I did not even know that this works, I always turned on the TV using the remote control beforehand.
I also did not test this after a really long time in standby, like next day. I could try to remember to test that tomorrow.
But it looks like the blame is more with your TV than with the router…
I agree with you because ive tested this only with samsung 7series and lg with same chromecast version. But this issue appiars only when i use mikrotik router. Have some additional packages installed/configured which differ from default? I can tell you more. If youll connect your tv to Google home then you can manage it with ok, google. Or setup to power on tv when you (your phone) entering room.
Just visited my friend with 7 series samsung and mikrotik. In standby mode chromecast unavailable too and he didn`t know that it works like this too.
I should note that both my TV and my Chromebook were on the same LAN segment (not my primary segment but a special one for this purpose).
Probably it will not work correctly when you use different segments and rely on some form of multicast routing.
I don’t have that on my router, there are 5 different segments but there is no multicast routing between them (and almost no normal routing).
Couldn`t solve the issue. Ordered zyxel keenetic. My practice of Mikrotik usage and install for home usage goes to end after more then 50 installed devices.
