Is it possible to establish a VPN connection from RB750 to Cisco 1800 using the below configuration…
DU-XYZ-1841#show run
Building configuration...
Current configuration : 4641 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname XXXXX
boot-start-marker
boot-end-marker
logging count
logging buffered 10000
enable secret 5 $1$6tsl$Eymq5zUkHIMfdsf32rwef
enable password 7 3dfdsvfsdcvfwe
aaa new-model
aaa authentication login USER local
aaa authorization network l-auth local
aaa session-id common
dot11 syslog
ip cef
ip inspect name FWOUT tcp
ip inspect name FWOUT udp
ip inspect name FWOUT icmp
ip inspect name FWOUT ftp
no ip domain lookup
ip domain name yfholding.com
multilink bundle-name authenticated
password encryption aes
username xduser password 7 070B226C570F110DEFSDSFA1B16020203
username du secret 5 $1$Vmp8$UEwV.6RUClcwerwugcgIQ8DaO.
username fvpn password 7 023FSDFS224D1B085F71
username ku password 7 063F29294342SDFSD0D100B103526
archive
log config
logging enable
hidekeys
crypto keyring dmvpnspokes
pre-shared-key address 0.0.0.0 0.0.0.0 key Verysecretoooo
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 10
encr 3des
hash md5
group 2
crypto isakmp client configuration group DUolding
key DUKey!@
pool VPN
acl 181
split-dns 192.100.100.100
crypto isakmp profile DMVPN
keyring dmvpnspokes
match identity address 0.0.0.0
crypto isakmp profile VPNclient
match identity group DUHolding
client authentication list USER
isakmp authorization list l-auth
client configuration address respond
crypto ipsec transform-set DU-SET esp-3des esp-md5-hmac
mode transport
crypto ipsec profile DU-PROFILE
set transform-set DU-SET
set isakmp-profile DMVPN
crypto dynamic-map IMAP 10
set isakmp-profile VPNclient
reverse-route
crypto map mymap 100 ipsec-isakmp dynamic IMAP
ip ssh version 2
interface Tunnel0
bandwidth 4000
ip address 192.168.234.1 255.255.255.0
no ip redirects
ip mtu 1440
ip hold-time eigrp 90 60
no ip next-hop-self eigrp 90
ip nhrp authentication cisco@DU
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 60
ip tcp adjust-mss 1360
no ip split-horizon eigrp 90
ip ospf network point-to-multipoint
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile DU-PROFILE
interface FastEthernet0/0
description LAN
ip address 192.100.100.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description WAN
ip address 82.195.135.2 255.255.255.248
ip access-group internet in
no ip redirects
no ip unreachables
ip inspect FWOUT out
duplex auto
speed auto
no cdp enable
crypto map mymap
router eigrp 90
redistribute static
redistribute ospf 1 metric 1 1 1 1 1
network 192.100.100.0
network 192.168.234.0
no auto-summary
router ospf 1
log-adjacency-changes
redistribute eigrp 90 subnets
network 192.100.100.0 0.0.0.255 area 0
network 192.168.234.0 0.0.0.255 area 0
ip local pool VPN 172.16.100.1 172.16.100.10
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 82.195.135.1
ip http server
no ip http secure-server
ip access-list extended internet
deny ip 0.0.0.0 0.255.255.255 any
deny ip 127.0.0.0 0.255.255.255 any
deny ip 192.0.2.0 0.0.0.255 any
deny ip 169.254.0.0 0.0.255.255 any
deny ip 224.0.0.0 31.255.255.255 any
deny ip 172.16.0.0 0.0.15.255 any log
deny ip 10.0.0.0 0.255.255.255 any log
deny ip 192.168.0.0 0.0.255.255 any log
permit esp any any
permit udp any host 82.195.135.2 eq isakmp
permit tcp host 212.98.130.56 eq 22 host 82.195.135.2
permit udp any host 82.195.135.2 eq non500-isakmp
permit gre any any
permit tcp host 174.8.7.53 host 82.195.135.2 eq 22
deny ip any any log
access-list 181 permit ip 192.100.100.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 192.168.40.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 10.20.10.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 194.194.0.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 192.168.0.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 10.20.20.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 193.193.0.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 10.55.55.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 181 permit ip 10.40.40.0 0.0.0.255 172.16.100.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
exec-timeout 30 0
logging synchronous
transport input telnet ssh
line vty 5 807
exec-timeout 60 0
transport input ssh
scheduler allocate 20000 1000
end
DU-XYZ-1841#
any advice/help would be highly appreciated!!!
