Cisco Aironet 340 not detected
Hi
I have a Aironet 340 PCI card but ROS will not detect it. I have tried in 3.0rc6 and also and older 2.9.29 and it is not seen by either.
Any ideas where I am going wrong?
Cheers
Daz
the Cisco Card support ist in V3 droped
http://www.mikrotik.com/download/CHANGELOG_rc
*) dropped support for Aironet/Cisco wireless cards;
Hi Thanks for the reply but I also got the same results using 2.9.29 - Have I gone too far back version wise for support?
Cheers
Daz
do you have the aironet package in 2.9 and did you check “/interface pc” menu? see:
http://www.mikrotik.com/testdocs/ros/2.9/interface/aironet.php
:blush: Found it :blush:
Thanks for the link to the cisco documentation - found it in the troubleshooting. The ROS had defaulted to licence level 1 demo which does not allow WIFI to work. I will purchase another licence so I can test before changing the live ROS boxes.
Many thanks
Darren
Hi. Please help.
Are Cisco Aironet 350 PCI also not support in Mikrotik OS v4.2?
In Interface`s page i found only ethernet interfaces. Wireless card is worked.
How activate this card? Also this card is present in:
/ system resource pci print
Thanks!!
yes, we have dropped support for them:
