Hi I have question?
I have successfully managed to test every tunnel connection from OVPN LT2P IPSEC PURE IPSEC and IKEV2 SSTP,
ShrewCLIENT works okey IPSEC to MIKROTIK WINDOWS
Does CIsco Any Connect can make connection to MIKROTIK via IPSEC tunnel or is different product only works in CISCO products?
Is it possible to connect IPSEC and SSTP with ANYCONNECT on IOS AND ANDROID.
I was trying to get some connection but IPSEC log says tfs padding not supported
SIMPLE QUESTION DOES IT WORK OR ONLY CISCO SERVER ROUTER
Thanks for HELP
