I am trying to make a vpls connection with a cisco7604, and seems that the tunnel never comes up.
I configure the cisco-bgp-vpls window, and in the vpls interface, come dynamically a connected one, but traffic between is not present.
At the cisco, some stuf is up, like ldp, and bgp l2vpn peer, but the tunnel never comes up completly.
Did anyone already configured bgp-based vpls against cisco.?
I received on cisco this message constantly:
cisco7604#
*Jan 26 13:36:05.899: %XCONNECT-5-PW_STATUS: MPLS peer 192.168.3.119 vcid 9999, VC DOWN, VC state DOWN
*Jan 26 13:36:05.899: %XCONNECT-5-PW_STATUS: MPLS peer 192.168.3.119 vcid 9999, VC UP, VC state UP
I attached peace of config.
cisco: peer: 192.168.3.191
mikrotik peer: 192.168.3.119
[admin@186] /interface vpls> print
Flags: X - disabled, R - running, D - dynamic,
B - bgp-signaled, C - cisco-bgp-signaled
0 RDC name=“vpls1” mtu=1500 l2mtu=1500 mac-address=02:F7:D3:09:70:63
arp=enabled disable-running-check=no remote-peer=192.168.3.191
vpls-id=65030:9999 cisco-style=no cisco-style-id=0
advertised-l2mtu=1500 pw-type=raw-ethernet vpls=vpls1
[admin@186] /interface vpls cisco-bgp-vpls> print detail
Flags: X - disabled, I - inactive
0 name=“vpls1” route-distinguisher=65030:9999 vpls-id=65030:9999
import-route-targets=65030:9999 export-route-targets=65030:9999 l2router-id=192.168.3.119
bridge=bridge3 bridge-cost=1 bridge-horizon=1
[admin@186] /routing bgp peer> print detail
Flags: X - disabled, E - established
0 E name=“peer1” instance=default remote-address=192.168.3.191 remote-as=65030 tcp-md5-key=“”
nexthop-choice=default multihop=no route-reflect=no hold-time=3m ttl=default in-filter=“”
out-filter=“” address-families=ip,l2vpn-cisco,vpnv4 update-source=192.168.3.119
interface=loopback0 default-originate=never remove-private-as=no as-override=no passive=no
use-bfd=no
[admin@186] /mpls ldp neighbor> print
Flags: X - disabled, D - dynamic, O - operational, T - sending-targeted-hello,
V - vpls
TRANSPORT LOCAL-TRANSPORT PEER SEN
0 DOTV 192.168.3.191 192.168.3.119 192.168.3.191:0 yes
[metronoc@186] /mpls ldp neighbor>
Cisco:
l2 router-id 192.168.3.191
l2 vfi vpls1 autodiscovery
vpn id 9999
vpls-id 65030:9999
rd 65030:9999
route-target 65030:9999
ip bgp-community new-format
mpls label protocol ldp
interface Vlan3000
xconnect vfi vpls1
cisco7604#sh xconnect all
Legend: XC ST=Xconnect State S1=Segment1 State S2=Segment2 State
UP=Up DN=Down AD=Admin Down IA=Inactive
SB=Standby HS=Hot Standby RV=Recovering NH=No Hardware
XC ST Segment 1 S1 Segment 2 S2
DN vfi vpls1 UP mpls 192.168.3.119:9999 DN
UP ac Vl3000:3000(Eth VLAN) UP vfi vpls1 UP
cisco7604#
cisco7604#sh mpls l2transport vc detail
Local interface: VFI vpls1 VFI up
Interworking type is Ethernet
Destination address: 192.168.3.119, VC ID: 9999, VC status: down
Output interface: none, imposed label stack {}
Preferred path: not configured
Default path: no route
No adjacency
Create time: 00:12:34, last status change time: 00:00:07
Signaling protocol: LDP, peer 192.168.3.119:0 up
Targeted Hello: 192.168.3.191(LDP Id) → 192.168.3.119, LDP is UP
Status TLV support (local/remote) : enabled/not supported
LDP route watch : enabled
Label/status state machine : activating, LruRru
Last local dataplane status rcvd: No fault
Last local SSS circuit status rcvd: No fault
Last local SSS circuit status sent: No fault
Last local LDP TLV status sent: No fault
Last remote LDP TLV status rcvd: Not sent
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 26, remote 155
AGI: type 1, len 8, 000A FE06 0000 270F
Local AII: type 1, len 4, C0A8 03BF (192.168.3.191)
Remote AII: type 1, len 4, C0A8 0377 (192.168.3.119)
Group ID: local n/a, remote n/a
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
Control Word: On (configured: autosense)
VC statistics:
transit packet totals: receive 4, send 0
transit byte totals: receive 344, send 0
transit packet drops: receive 0, seq error 0, send 0
cisco7604#
cisco7604#sh ip bgp l2vpn vpls all summary
BGP router identifier 192.168.3.191, local AS number 65030
BGP table version is 59, main routing table version 59
2 network entries using 296 bytes of memory
2 path entries using 120 bytes of memory
2/2 BGP path/bestpath attribute entries using 248 bytes of memory
1 BGP extended community entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 688 total bytes of memory
BGP activity 19/12 prefixes, 35/28 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
192.168.3.119 4 65030 736 713 59 0 0 10:36:48 1
Mikrotik log:
Jan/02/1970 11:55:32 route,debug,event Interface change
Jan/02/1970 11:55:32 route,debug,event interface=vpls1
Jan/02/1970 11:55:32 route,debug,event status=UP
Jan/02/1970 11:55:32 route,debug,event mtu=1500
Jan/02/1970 11:55:32 route,debug,event status=UP,RUNNING
