I have to make a decision this week on buying a Cisco or sticking with our MT core.
We have a location that is fed via multiple ADSL lines. We are moving them over to a provider that supports
bonding them. They want to use Cisco per packet CEF. This post below says CEF is supported (core is running
3.22 but will be regressed to 3.20 due to some queues bugs)
http://forum.mikrotik.com/t/cisco-cef-load-balancing/879/1
I have looked in all the documentation and can not find anything about how to configure CEF support. Does anyone have a example of how to configure it or where in the manual it is located?
