How can I implement below scenario in CRS and CCR?
Cisco small business switch configure as port based vlan and trunking vlan10, vlan20, vlan30
So i’m trying to configure a CRS and CCR like this sample config:
CRS1:
set sfp1-slave-local master-port=ether1-master-local
set sfp2-slave-local master-port=ether1-master-local
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1-master-local,sfp1-slave-local,sfp2-slave-local vlan-id=10
add tagged-ports=ether1-master-local,sfp1-slave-local,sfp2-slave-local vlan-id=20
add tagged-ports=ether1-master-local,sfp1-slave-local,sfp2-slave-local vlan-id=30
add ports=ether1-master-local,sfp1-slave-local,sfp2-slave-local vlan-id=10 learn=yes
add ports=ether1-master-local,sfp1-slave-local,sfp2-slave-local vlan-id=20 learn=yes
add ports=ether1-master-local,sfp1-slave-local,sfp2-slave-local vlan-id=30 learn=yes
CRS2:
same as CRS1
CCR:
/interface bridge add name="FiberBridge" disabled=no
/interface bridge port add interface=ether1 bridge=FiberBridge
/interface bridge port add interface=ether2 bridge=FiberBridge
/interface vlan
add name=vlan10 vlan-id=10 interface=FiberBridge
add name=vlan20 vlan-id=20 interface=FiberBridge
add name=vlan30 vlan-id=30 interface=FiberBridge
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
