Cisco IPsec To Mikrotik
Hi Guys
I have config on cisco router and ip want to transfer it to mikrotik
any one can help me how to config this on mikroitk please:
Crypto isakmp enable
crypto siakmp policy 10
encr 3des
hash md5
authenticatio pre-share
crypto isakmp key ix979738686 address 10.10.10.1
crypto ipsec transform-set tets-ipsec esp-3des esp-sh-hmac
mode transport
crypto ipsec profile test-ipsec
no one can help me ?
It is probably not that difficult… Here is a good example:
https://help.mikrotik.com/docs/display/ROS/IPsec#IPsec-SitetoSiteIPsec(IKEv1)tunnel
And please.. upgrade your security to IKEv2, AES(preferably AES-GCM), etcetera…
3DES / MD5 is a joke.
I do this but not work
can you help me please:
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=3des hash-algorithm=md5 name=Profile-Test
/ip ipsec peer
add address=78.39.x.x/32 local-address=185.x.x.x name=Profile-Test
passive=yes profile=Profile-Test
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add auth-algorithms=md5 enc-algorithms=3des name=Profile-Test
/ip ipsec identity
add peer=Profile-Test secret=secret
/ip ipsec policy
add dst-address=78.39.x.x/32 level=unique peer=Profile-Test proposal=
Profile-Test src-address=185.x.x.x/32
Are you sure about the source and destination addresses in the ipsec policy?
You should configure here the subnets being routed through the ipsec tunnel.
I have Gre tunnel and i want to work on gre:
Gre tunnel:
source address:185.x.x.x /32
Dst address :78.39.x.x/32
Tunnel IP: 192.168.1.2/30
/ip ipsec profile
/ip ipsec peer
/ip ipsec proposal
/ip ipsec identity
/ip ipsec policy
try this
/ip ipsec peer
add address=78.39.x.x/32 name=Profile-Test profile=Profile-Test send-initial-contact=yes
/ip ipsec policy
add dst-address=78.39.x.x/32 src-address=185.x.x.x/32 protocol=47 level=require peer=Profile-Test proposal=Profile-Test
… or do not bother about IPsec config on the MikroTik and just create the IPsec tunnel with an IPsec password. That will auto-generate the settings.
However, getting IPsec to work between different manufacturers is not so simple. You need experience and persistence.
“can nobody help me” usually brings you nothing because it is not possible to verify these things from the outside, especially when you make so many typing mistakes (rather than using cut/paste).
Also of course you (should) know that IPsec in transport mode cannot work over NAT. So when your MikroTik is not directly connected but behind some ISP-provided NAT router, it is never going to work!
Well one could try a network simulator…
But some low-effort posts do seem like a waste of someone’s time. It’s not clear what’s even broken here. Is there no association or no routing?
