Ok, I have a mikrotik network routers and wireless devices.. One of my users is having a hard time with his Cisco VPN3002 concentrator. It connects and establishes the IPSEC VPN. The user can ping devices in his internal network and a tracert shows that all packets are tunneled to his network and leaving through his internet gateway.
Here’s the catch, the user can not authenticate with his windows 2003 domain, nor can he RDP (Remote Desktop) to his servers. And none of his network based applications function.
I have a Mikrotik as my edge router and all devices in my network all mikrotik (wireless bridges). The edge router is also doing minor firewalling. The WAN port has a Point to Point link to my upstream provider (/30 subnet). The only ports I’m currently blocking are incoming 25 (tcp), 135-139 (tcp/udp), and 445 (tcp).
Now before any of you blurt out and say “well thats why he can’t authenticate, you’re blocking NetBIOS and Microsoft Directory Services” he is connecting to his network through a VPN Tunnel. Aside from the Mikrotik ripping apart the VPN tunnel and dropping those packets within the tunnel (which I’ve yet to see a firewall do), I can’t seem to explain this. And just to be sure I put in an Accept rule for his IP address so that all packets destined for his static IP address were accepted.
I want to pass it off to the client and say it’s a problem with his internal network, but when he plugs the same device into another ISP it works flawlessly.
Here’s the layout of the network. Client’s Cisco VPN3002 → Tranzeo/Mikrotik/Zcomax CPE (i’ve tried all three same results) → Mikrotik AP (2.4) → switch —> Mikrotik WDS-Station (5.8 ) —> Mikrotik AP (5.8 ) —> Layer3 switch —> Allot Netenforcer —> Mikrotik Edge Router —> upstream provider fiber MPLS network.
I’ve been beating my head up against a wall on this one, any suggestions?
I even had him take his Cisco 3002 from the client location to the next hop up to rule out the 2.4 link, plugged in and got the same results. This all worked for two months straight, we made some network upgrades. We swapped out a 5.8 PtP link that was underutilized for a 5.8 PtMP, removed are cisco 2600 series edge router and replaced with a mikrotik… And now he has problems… My brain is fried, I’ll check back tomorrow.
-Bill
P.S. I’m using 2.9.17 on all mikrotik devices..
and I guess I should mention there’s no NAT being done on my network, all nodes get publicly routeable IP addresses.
