Cisco VPN Client cannot connect tru Mikrotik
Hi
Im running mikrotik router since this week and now i cannot connect to my work VPN connection like the packets never leave my mikrotik.
Is this an known issue or do i have to setup rules for this, i cant find anything for VPN Pass-Tru
Set Proxy-Arp to On on the internal interface.
Nope it is still not working
  • Changed ARP from enabled to proxy-arp
  • Reboot MT
  • Still not working
Anybody Else
I`m using PPTP for connection to my DSL provider and want to connect over the pptp connection to my work using cisco vpn client
Cisco VPN client is working fine for me through Mikrotik, so it must be some difference in the configuration or that fact that you are already working over a PPTP link.
When i got home this evening i had my work laptop with me, when i plugged in the cisco aironet wlan to connect it to my wlan which is connected to my MT-Box every thing works,
Gave up a static ip because i forgot to config dhcp and after this i just connect to Cisco VPN without any problem.
So i think its my own pc how is having issues, but when i dial in over the internet to the Win2k VPN server on my lan interface i cannot dial further over the vpn connection to the Cisco VPN Connection So i think the lan interface of my MT-Box is bugging me and not my PC.
MT-Box Settings
LAN 192.168.100.250
WAN 10.0.0.150
PPTP dial up over the WAN interface to my DSL modem.
WLAN 192.168.50.250
All interface have only ARP-Enable not ARP-Proxy
When i`m back home i will try to connect using my on pc, using the WLAN interface
After Removing NIC Express from my workstation and reinstalling the Cisco VPN Client everything works fine. :laughing:
