Ok, here you go……………..there’s a bunch………
Cisco Systems VPN Client Version 4.6.04.0043
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 1
Config file directory: C:\Program Files\Cisco Systems\VPN Client
1 15:23:08.765 02/10/06 Sev=Warning/2 CVPND/0xE3400013
AddRoute failed to add a route: code 87
Destination 192.168.1.255
Netmask 255.255.255.255
Gateway 172.21.144.14
Interface 172.21.144.14
2 15:23:08.765 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: c0a801ff, Netmask: ffffffff, Interface: ac15900e, Gateway: ac15900e.
3 15:23:08.765 02/10/06 Sev=Warning/2 CVPND/0xE3400013
Destination 216.192.202.255
4 15:23:08.765 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: d8c0caff, Netmask: ffffffff, Interface: ac15900e, Gateway: ac15900e.
5 15:26:55.264 02/10/06 Sev=Warning/3 CM/0xA3100027
Adapter address changed from 216.192.202.1. Current address(es): 172.21.144.14, 192.168.1.101.
6 15:26:55.280 02/10/06 Sev=Warning/2 CVPND/0xA340000E
Failed to get adapter index.
7 15:26:56.498 02/10/06 Sev=Warning/2 IKE/0xA3000067
Received an IPC message during invalid state (IKE_MAIN:507)
8 16:22:35.295 02/10/06 Sev=Warning/2 CVPND/0xE3400013
Gateway 172.21.144.19
Interface 172.21.144.19
9 16:22:35.295 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: c0a801ff, Netmask: ffffffff, Interface: ac159013, Gateway: ac159013.
10 16:22:35.295 02/10/06 Sev=Warning/2 CVPND/0xE3400013
Destination 216.192.201.255
11 16:22:35.295 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: d8c0c9ff, Netmask: ffffffff, Interface: ac159013, Gateway: ac159013.
12 16:57:57.372 02/10/06 Sev=Warning/3 CM/0xA3100027
Adapter address changed from 216.192.201.7. Current address(es): 172.21.144.19, 192.168.1.101.
13 16:57:57.372 02/10/06 Sev=Warning/2 CVPND/0xA340000E
14 16:57:58.747 02/10/06 Sev=Warning/2 IKE/0xA3000067
15 17:00:15.747 02/10/06 Sev=Warning/2 CVPND/0xA3400011
Error -21 sending packet. Dst Addr: 0xC0A801FF, Src Addr: 0xC0A80165 (DRVIFACE:1152).
16 17:02:31.606 02/10/06 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: GetAdaptersInfo, error 0
17 17:02:31.715 02/10/06 Sev=Warning/2 CVPND/0xE3400013
Gateway 172.21.128.18
Interface 172.21.128.18
18 17:02:31.715 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: c0a801ff, Netmask: ffffffff, Interface: ac158012, Gateway: ac158012.
19 17:02:31.715 02/10/06 Sev=Warning/2 CVPND/0xE3400013
Destination 216.192.196.255
20 17:02:31.715 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: d8c0c4ff, Netmask: ffffffff, Interface: ac158012, Gateway: ac158012.
21 17:11:22.497 02/10/06 Sev=Warning/3 CM/0xA3100027
Adapter address changed from 216.192.196.4. Current address(es): 172.21.128.18, 192.168.1.101.
22 17:11:22.512 02/10/06 Sev=Warning/2 CVPND/0xA340000E
23 17:11:23.997 02/10/06 Sev=Warning/2 IKE/0xA3000067
24 17:11:52.637 02/10/06 Sev=Warning/2 CVPND/0xA3400011
25 17:14:43.872 02/10/06 Sev=Warning/2 CVPND/0xE3400013
Gateway 172.21.128.29
Interface 172.21.128.29
26 17:14:43.872 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: c0a801ff, Netmask: ffffffff, Interface: ac15801d, Gateway: ac15801d.
27 17:14:43.887 02/10/06 Sev=Warning/2 CVPND/0xE3400013
Destination 216.192.199.255
28 17:14:43.887 02/10/06 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: d8c0c7ff, Netmask: ffffffff, Interface: ac15801d, Gateway: ac15801d.
29 17:34:07.752 02/10/06 Sev=Warning/3 CM/0xA3100027
Adapter address changed from 216.192.199.2. Current address(es): 172.21.128.29, 192.168.1.101.
30 17:34:07.752 02/10/06 Sev=Warning/2 CVPND/0xA340000E
1 17:35:33.674 02/10/06 Sev=Info/4 CERT/0x63600013
Cert (cn=WA763267-WAH,ou=StandardWks,ou=Workstations,dc=OA2,dc=aeth,dc=aetna,dc=com) verification succeeded.
2 17:35:33.674 02/10/06 Sev=Info/4 CM/0x63100002
Begin connection process
3 17:35:33.674 02/10/06 Sev=Warning/2 CVPND/0xA3400011
4 17:35:33.689 02/10/06 Sev=Info/4 CM/0x63100004
Establish secure connection using Ethernet
5 17:35:33.689 02/10/06 Sev=Info/4 CM/0x63100024
Attempt connection with server “xtranet1.aetna.com”
6 17:35:33.767 02/10/06 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 206.213.215.16.
7 17:35:33.767 02/10/06 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM (SA, VID(Xauth), VID(dpd), VID(Nat-T), VID(Frag), VID(Unity)) to 206.213.215.16
8 17:35:33.783 02/10/06 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
9 17:35:33.783 02/10/06 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
10 17:35:33.783 02/10/06 Sev=Info/6 IPSEC/0x6370002C
Sent 966 packets, 0 were fragmented.
11 17:35:33.783 02/10/06 Sev=Info/4 IPSEC/0x6370000D
Key(s) deleted by Interface (216.192.199.2)
12 17:35:33.861 02/10/06 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 206.213.215.16
13 17:35:33.861 02/10/06 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM (SA, VID(Nat-T), VID(Frag)) from 206.213.215.16
14 17:35:33.861 02/10/06 Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
15 17:35:33.861 02/10/06 Sev=Info/5 IKE/0x63000001
Peer supports IKE fragmentation payloads
16 17:35:33.861 02/10/06 Sev=Info/6 IKE/0x63000001
IOS Vendor ID Contruction successful
17 17:35:33.861 02/10/06 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM (KE, NON, NAT-D, NAT-D, VID(?), VID(Unity)) to 206.213.215.16
18 17:35:33.986 02/10/06 Sev=Info/5 IKE/0x6300002F
19 17:35:33.986 02/10/06 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM (FRAG) from 206.213.215.16
20 17:35:33.986 02/10/06 Sev=Info/5 IKE/0x6300002F
21 17:35:33.986 02/10/06 Sev=Info/4 IKE/0x63000014
22 17:35:33.986 02/10/06 Sev=Info/5 IKE/0x63000073
All fragments received.
23 17:35:33.986 02/10/06 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM (KE, NON, CERT_REQ, CERT_REQ, CERT_REQ, CERT_REQ, CERT_REQ, CERT_REQ, CERT_REQ, CERT_REQ, VID(Unity), VID(Xauth), VID(?), VID(?), NAT-D, NAT-D) from 206.213.215.16
24 17:35:33.986 02/10/06 Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
25 17:35:33.986 02/10/06 Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
26 17:35:33.986 02/10/06 Sev=Info/5 IKE/0x63000001
Peer supports DWR Code and DWR Text
27 17:35:34.158 02/10/06 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM *(ID, CERT, CERT_REQ, SIG, NOTIFY:STATUS_INITIAL_CONTACT) to 206.213.215.16
28 17:35:39.252 02/10/06 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
29 17:35:39.252 02/10/06 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM *(Retransmission) to 206.213.215.16
30 17:35:41.970 02/10/06 Sev=Info/5 IKE/0x6300002F
31 17:35:41.970 02/10/06 Sev=Info/4 IKE/0x63000014
32 17:35:41.970 02/10/06 Sev=Info/5 IKE/0x6300002F
33 17:35:41.970 02/10/06 Sev=Info/4 IKE/0x63000014
34 17:35:41.970 02/10/06 Sev=Info/5 IKE/0x63000073
35 17:35:41.970 02/10/06 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM (Retransmission) from 206.213.215.16
36 17:35:41.970 02/10/06 Sev=Info/4 IKE/0x63000021
37 17:35:41.970 02/10/06 Sev=Info/4 IKE/0x63000013
38 17:35:47.252 02/10/06 Sev=Info/4 IKE/0x63000021
39 17:35:47.252 02/10/06 Sev=Info/4 IKE/0x63000013
40 17:35:49.970 02/10/06 Sev=Info/5 IKE/0x6300002F
41 17:35:49.970 02/10/06 Sev=Info/4 IKE/0x63000014
42 17:35:49.970 02/10/06 Sev=Info/5 IKE/0x6300002F
43 17:35:49.970 02/10/06 Sev=Info/4 IKE/0x63000014
44 17:35:49.970 02/10/06 Sev=Info/5 IKE/0x63000073
45 17:35:49.970 02/10/06 Sev=Info/4 IKE/0x63000014
46 17:35:49.970 02/10/06 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=87462B901B72E52E R_Cookie=F230BF4D0C7B9C10) reason = DEL_REASON_PEER_NOT_RESPONDING
47 17:35:49.970 02/10/06 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DWR) to 206.213.215.16
48 17:35:50.752 02/10/06 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=87462B901B72E52E R_Cookie=F230BF4D0C7B9C10) reason = DEL_REASON_PEER_NOT_RESPONDING
49 17:35:50.752 02/10/06 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server “xtranet1.aetna.com” because of “DEL_REASON_PEER_NOT_RESPONDING”
50 17:35:50.752 02/10/06 Sev=Info/4 CM/0x6310000C
All connection attempts with backup server failed
51 17:35:50.752 02/10/06 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
52 17:35:50.752 02/10/06 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
53 17:35:50.752 02/10/06 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
54 17:35:50.752 02/10/06 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
55 17:35:50.767 02/10/06 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
56 17:35:50.767 02/10/06 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
It should be noted that this same configuration works fine on a competitior wi-fi network that does not use routing. it also works via DSL. we run exclusively Motorola Canopy and until very recently everything worked perfectly, then the problem became apparent one weekend and then stopped alltogether.
We have no filters on internal routers and the external policies on the border router have not changed. Of couse the customers employer IT department claims no changes on their side at all and everyone else can work just fine.
