Hello, I’d like to know the way to clean the logs on Disk. I have enabled logging on disk and now I want to clean that log, in order to free up the space on HDD. How can I Do ?
I Use ROS 3.17 on x86.
Thanks with the best Regards Karapet Aznavuryan
does setting the “log lines” to “1” help?
I think it is done. Now when I look at logs on Disk, I see just 1 line.
When logs are saved on disk, where do I find them?
Same as before - ‘/log print’
the only difference is that they don’t clear after reboot
