CLEAR Command
Hi there ..
is there in MikroTik terminal any command such like cls in Windows or clear in Linux ?
i need it to clear my screen .. some tim i still press ENTER for a time to clear my screen !!
thanks for reading and/or replay
nope, but if you use putty or securecrt, you have the option there.
im useing PUTTY .. what is the command that i can to use ?
and what is the login protocol SSH or TELNET .. to be able running this command ?
thanx
click on the upper left icon and you’ll see the option “reset terminal” (in windows).
Control-L or F5
reset terminal and repaint screen.
http://wiki.mikrotik.com/wiki/Manual:Console
