Clearing Chart data
I would like to know how I can remove the data that The Dude uses to generate graphs in order to shrink the exported file size and to have clean graphs when starting The Dude.
I have been testing several configurations and now that I am about to settle for one, I would like to see the charts start fresh from blank, instead of the data thats been compiled througout my testing.
I need to know this as well …
Last time I exported and imported the XML all the graphs were empty, YMMV.
It seems to me that if you add mibs and graphics those also get added to the XML.
You could edit the XML and find files and manually remove them… be careful.
You can also reduce/delete syslog sizes to reduce the export.
GL
