I had a client who’s laptop i could not get to see the ssid of any of my 15 WRAP 2c boards with 2 8602 cards in them each. (in windows)
This was a new toshiba laptop and was picking up my engenius access point SSID and some 2 random Linksys’s. It was able to connect and surf on any of those. however none of my wrap + MT configs were showing up.
ANyone had this issue? I tried chaning the channel and even chaning modes just to get the ssid to show up…nothing here is the wirelss config for that floor (actually its pretty much the same for every floor):
note: other clients have connected and continue to connect to these floors too.
name="wlan1" mtu=1500 mac-address=00:02:6F:3E:1F:29 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name="00026F3E1F29" mode=ap-bridge ssid="BeachColony_2d15L"
area="" frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=2412 band=2.4ghz-b/g scan-list=default
rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
thanks
joe
