client connected but not vissible?
Hi guys I have a wireless client that is connected to one of the caps, it has an IP within the DHCP range and I can connect to it. But, the client is not visible in the mikrotik interface, I can see it in the wifi menu under registration, but it does not show up under the DHCP server and leases part of the UI. I have tried to kick the client but it just reconnects and is still not visible in the DHCP server part.
sounds like the client manually set a static IP ..
Is it visible in /IP/ARP ?
Nope no shown under IP/arp either…
But I checked the config and yes the IP was set to static for some reason, has apparently been so since a few years, but since updating to 7.14.2 it showed to be “gone”…
Removing the static config solved the issue, thank you!
