i have set 133c with r52 to connect the base station; r52 is set to station mode in 2.4ghz; scaned and connected to base without any problem; bridge the wlan1 end ether1 interfaces ( i know it can not be bridged; but i couldnt get the ip via dhcp anyother ways); DNS and gateway address are registered; but cant ping the server and access the login page; when i try to connect via wds-station (and bridge interfaces as referred) ; no way to connect to the base station. Any ideas how to connect properly to base and get the ip via dhcp? bdw another question from interfaceses; r52 is connected to network but; no send / receive ? and the icon is disabled (unlike the LAN) ?
Do you have proper WDS configuration on the other side of the link (on the access point), when mode=station-wds is used ?
sergejs ; i ve tired that; but when i try to connect as wds-station; device stucked at searching for network; i guess no; hotspot does not have proper connection.
Maybe I misunderstand what you want to achieve, but you did not explain that very well.
If you just want your RouterOS to be a client to another AP and get your ip address via DHCP:
- Configure the wlan interface as station.
- Configure a DHCP client on the wlan interface.
- Probably configure a masquerading rule for traffic going out the wlan interface.
Best regards,
Christian Meis
yes its exactly what im trying, enabled the masquerade but how can i config the dhcp client on wlan interface ? bdw upgrade the ros to 3.0beta10 , bord has crashed as its stated by someone else aswell , now tryin to re-instal via netinstal but still can get bios, since the comp. frezez when u press any key on keyboard!
To configure a DHCP client on the wlan interface, just go to IP->DHCP Client and add one for the wlan interface you need it on!
Best regards,
Christian Meis
christian thank for you post; problem has been solved; i found out it under the ip section after your post; then created a dhcp server for lan interface; added gateways and dns ; signal is -41 and rocks ![]()
Hai
nice to read this topic, but it signal -41 i think to stronge, the best signal -45/-50
my suggestion is better will you decrease it signal.
regards
Hasbullah.com
balimore what could go wrong with srong signal ? might sound a silly question
just moved to mikrotik rather than traditional APs ..
yup,
as far as i remember, last time ago i have signal from cpe -36 until -43, than my cpe have good signal but poor quality every time a few second the wireless down a few second up again.
and now stable in -48/-54
if your suggestion best for you do it. ![]()
