I would like my client radios to hand down private dhcp such as a 192.168.1.1 over eth1 rather than what I am currently doing which is a completely bridged network. Ideally each radio will have a private static ip for management logins through dude (172.16.0.x) and hand down dhcp to the client router/computer (192.168.1.x)
I’ve tried setting it up before but I missed something. Can someone tell me how to accomplish my goal through winbox or webbox?
This is the only method I found to reliably do what you’re asking without resorting to running WDS w/ VLANs on each client. The downside is it requires static IPs for each CPE and manual setup of the VPLS tunnels.
Many thanks, I’ll spend some time understanding what you posted.
At first glance it looks like the ap is handing dhcp to each client radio?
I’d like the ap and client radio to stay on a fixed ip then have the client radio act as a router passing dhcp down to the customer computer/router etc. I might reword my question after review.
internet/gateway(172.16.1.1) <----bridge----> AP(static management ip 172.16.1.2) <----bridge----> CPE(static management ip 172.16.1.3 then hand dhcp down eth1 192.168.1.1/24) <—dhcp—> Client router/computer
If I understand the above post correctly it would put dhcp above the cpe not below it. Correct me if I’m wrong as this is why i’m asking. If I do this then the ap and cpe will bridge and dhcp will come down from the ap through the cpe to the client putting all cpes connected to that ap on the same dhcp lan?
I went through the link above but I don’t think that will do what I am I looking for. Can I do dhcp at the cpe or does it have to come from the ap through the cpe to the clients router/computer?
I’m used to Motorola canopy equipment and am new to MK. I have been able to put canopy ap’s/cpe on public fixed ips then have the cpe hand down dhcp as I am trying to do here but haven’t had any luck on the MK side.
My goals are to provide the security of using private ips to manage the infrastructure and keep my public pool open.
My second goal is to get away from having a bridged network for obvious reasons.
Right now the network infrastructure is bridged all the way through with private ips and hands down public ips from the gateway router. Help me get away from a bridged network.
