client keeps reassociating? what is that
Hallo my client keeps on reassociating every 30 seconds. can someone help me to relove this plz. thanx
enable wireless debug logs (add logging topic “wireless and debug”) and see what you have in the log then
The logs keeps on saying disconnected, reassociating, and then cnnected. I exented the height of my grid so now the signal strengh is 70%.
Ive looked around in the forums, another user seems to have the same issue, i will try thier plan.
if you correctly enable debug logs, there will be more information than that:
http://wiki.mikrotik.com/wiki/Wireless_Debug_Logs
Thank you i addes that rule, what is gives to me now is
EMI: 00:02:6F:48:82:E7 attempts to assocoate
EMI: 00:02:6F:48:82:E7 reassoiating
EMI: 00:02:6F:48:82:E7 desconnect, ok
EMI: 00:02:6F:48:82:E7 not in local ACL, by default accept
What can do to resolve this?
the problem must be in client
The client have a senao router, will this make the connection suffer speeds and throughput and so on? Or can i ignore this.
what is the signal in the client? maybe he is simply too far, or something is blocking their view. either way, the log doesn’t show any problems with the connection, it just says that client disconnected because it wanted to.
The signal is usually 66% The cloent is 1.2km away from the AP. When the wind is strong then the signal differs from 30% to 80%. Im using two 24dbi 2.4ghz grids. The client is able to play online gaming.
the mikrotik seems to be slow now that i have upgraded the firmware. Most of the time is says time out when i try to access it using winbox and with telnet it stops at the large mikrotik logo, does not show any command prompt. why is it so slow?
Hallo there what dioes the foloowing means? The first line of the class 3 and also the 3rd line of local ACL? How can i prevent that errors.
00:02:6F:44:17:B4@EMI: disconnected. recieved disassoc: class 3 frame recieved (7)
EMI: 00:02:6F:44:17:B4 attempts to associate
EMI: 00:02:6F:44:17:B4 in local ACL, accept
00:02:6F:44:17:B4@EMI: connected.
