(alt+p)
anyone see the problem or a solution[/img]
(alt+p)
i will try the link
Directional Antennas from Central Tower to A and B may help.
Ok either no one has had an issue like this or they do not know how to fix it ??
ok the cpus on oll 532’s are set to 264 should i over clock them to 333 would this help??
Post your frequency used.
if A and B are on the same SECTOR then that radio will have to RX the packet from one then TX it to the other - remember, 802.11 is half duplex. This will result in half the bandwidth you think you should get.
