Basic and supported rates are set to 11Mbit.
Client with D-Link DWL-520+ is connecting 11/1 Mbit.
Why? Is there any solution to connect 11/11 Mbit?
What channel are you using? You may be getting interference from other units that’s causing the signal to be swamped in one direction.
What antennae are you using at each end? If the DWL-520+ is using a standard 2dB antenna then maybe you need to add a higer gain one.
Regards
Chris Macneill
Thank You, bu t i think it is’nt channel or signal problem. I was trying all channels (1-13). The signal strength is -72 to -74 (at MT side).
Another clients connecting 11/11 Mbit, but DWL-520+ is not, why?
is it always 11/1 ?
mayby user doesn;t use it at the moment, just reading the www, ask him/her to turn on p2p and watch
Unfortunately - always ![]()
But problem is only withl D-Link DWL-520+ cards. I have tested three pieces of dwl-520+ and always the same:( Another cards works OK.
Why d-link sucks?![]()
Is the 520+ the ABG with the antenna permanently connected by a 4ft run of thin coax?
The Dlink drivers suck, the generic Atheros drivers make a huge difference.
No, it’s exactly DWL-520+ (B/G only), with RPSMA connector.
Which drivers do you recommend for this model?
