I have just installed one of the Mikrotik CPE units and for some unknown reason the client PC is not able to browse the internet. This is the configuration:
Wlan=station mode ip address=192.168.2.26 gateway=192.168.2.7
ether1 ipaddress = 192.168.10.1 dhcp-server enabled
Client PC ipaddress=192.168.10.2 gateway=192.168.10.1
Standard Nat rule set 0 chain=src-nat out-interface=wlan1 action=masquerade
The problem I am facing is.
I can ping the remote gateway 192.168.2.7 from the router when connect via telnet to the wlan interface.
I can ping the remote gateway 192.168.2.7 from the router when connect via telnet to the ether1 interface.
I can ping the wlan interface 192.168.2.26 from the client PC
4.I cannot ping the remote gateway 192.168.2.7 from the client PC.
5.I cannot ping the client from the router either. The client has been allocated an ipaddress from the router of 192.168.10.2.
Can anyone tell me what I have missed.
Thanks Mark
sounds like you nat rule isn’t working correctly…
Hi Forepoint,
Is there any other way of fixing this problem. I have even added a static route to the AP that the client connects to. I can ping from the main AP all the way back to the 192.168.10.1 address.
Thanks Mark
do you have a software firewall turned on at the client machine?
try another client to rule out problems with it.
Forepoint the client can ping the wlan interface 192.168.2.26 ???
if you can ping wlan1, but not the AP, it sounds like your NAT rule isn’t working…
also, with having NAT in place, you will not be able to ping the client from the host AP…
Forepoint,
If I remove nat what else can I setup. I have static routes
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 ADC 192.168.2.0/24 192.168.2.26 wlan1
1 ADC 192.168.10.0/24 192.168.10.1 ether1
2 A S 0.0.0.0/0 r 192.168.2.7 wlan1
[mark@MikroTik] >
why remove nat? you don’t need access from the AP all the way to the PC do you?
Forepoint,
I have disabled nat and the PC is now getting an ipaddress from the Network DHCP server …and I can ping the PC’s ipaddress now. I am just waiting for the user to tell me if they can browse.
I agree Nat would be good but it’s not working correctly.
Mark
